Question about Kenmore Washing Machines
The washing machine fills up,then it stops.I believe the problem to be in the switch.Question is which one.Lid switch or selector.Which one is most likely?I live a long way from the nearest repair shop,so the house call will be over $100.and that is only to diagnose the problem.Once he orders the part,he will come back a week later,and its another $100 plus the cost of the switch.The selector switch is over $175.plus tax.If I can't do this myself ,it would be just as cheap to buy a new washer.I hate to do this as my machine is a top of the line 5 year old Kenmore.How can I find out whitch one it is without tearing the machine apart?We got access to the switches,But is there a simple way to test.I am a 68 year old pensioner,with limited funds.Please help. Thank you
  • Alexx1943 Oct 04, 2010
    This solution was right on.I did what you suggested,and the problem is the lid switch.You were a big help.Thank you so much
  • 4,059 Answers
Just unplug the two wires to the lid switch and temporarily tape them together thus bypassing the switch. If the washer works normal now then the lid switch is not working. If it still fill and stops then it's likely the selector switch. Try it on different settings such as low level and different types of washes to see if it works any where and advance it in the cycle to see if it works there.
Posted on Oct 04, 2010
Maytage Dependable Care washing machine will not operate. Lid switches, timer check out. Fuse is good. Machine is getting power. Machine will not fill, agitate, or spin. Timer does not advance.
Sounds like the timer motor is fried. Remove it, connect it to a 110/120 volt power source and listen to it. If you can hear it running, then that's cool. Next, move the selector switch to the next mode manually and see of your machine responds to that. If it does, then the motor for the timer needs to be replaced, it probably lacks the torque needed to move the selector switch around.
Jan 23, 2014 | Washing Machines
The washer turns on and fills up but then stops. If you bang the lid a few times it will usually continue on the cycle and be fine. You have to repeat the lid banging for every load though. The lid...
Sounds like the switch that the lid presses is either broken or has been knocked loose.
Or the little plastic or metal "switch actuator" (the little poker) that presses the switch has broken.
I believe the washer thinks the lid is open because it will fill up but wont't wash until it knows the lid is shut.
Jul 18, 2011 | Whirlpool Washing Machines
Washing machine fills with water but will not go on to the wash cycle . The machine just fills with water and stops. Have to bail out the water by hand.
Your lid switch needs to be reset or replaced. Open the control console to access the lid switch. Check the fuse for continuity. Check the alignment of the lid switch for contact with the micro switch.
If these cannot be reset they must be replaced.
Oct 08, 2009 | Maytag Washing Machines
Starts and stops immediately
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 03, 2009 | Washing Machines
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing machine
possible bad or burned contacts inside timer assembly
Dec 27, 2007 | Washing Machines
Fills with water and stops I do not hear timer clicking
Your repairman was pulling your leg. There is no "reset" switch on these. The lid switch is bad. You know how, when it is washing clothes, you can lift the lid and the machine shuts down? That's the lid switch doing that. Now, you lid switch is failed, so the machine thinks the lid is open. Replace the switch and all is well in the world. The part number is #12001187 and lists for ~$14.00. Can be purchased at your local appliance parts store.
Jul 31, 2007 | Maytag PAV3240A Top Load Washer
Washing Machines Logo
170 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
