Question about Dell OptiPlex GX150 SF PC Desktop
Does desc top computers come with Quad Processors?
    Problem Solver:
  • 10 Answers
While some desktops come with quad-core processors, unfortunately the Dell OptiPlex GX150is not one of them.
Posted on Feb 28, 2011
How Is a Q6600 core 2 quad cpu compatible with a foxconn g41 mxe-v motherboard?
Yes it's compatible. The type of motherboard can be any board that uses "Socket 775".
Aug 07, 2014 | Intel Computers & Internet
Installing wi-fi drivers for asus z87 motherboard
If the device has no Wi-fi device activated , it will not run a driver install
Mar 01, 2014 | ASUS Z87-DELUXE LGA1150/ Intel Z87/ DDR3/...
CAN I INSTALL XEON 5540 WITH LGA1366 MOTHERBOAR
NOT ON JUST ANY MOTHERBOARD, that's a quad core, the mother board has to have quad core clocking. You need a server board. All the desktop boards are only dual core clocking.
Feb 20, 2014 | IBM Xeon E5540 FCLGA1366 2.53G 8MB 45NM...
SuperMicro X7DB8 - upgrading from two dual core to two quad core CPUs , carefully installed the quad cores and duct taped it all back together ... no post , no anything ... havent connected a speaker...
SuperMicro Support > SuperMicro X7DB8 Server Motherboard > Main Support page,
http://www.supermicro.com/products/motherboard/xeon1333/5000p/x7db8.cfm
Motherboard User's Manual download page,
http://www.supermicro.com/support/resources/results.cfm
[ MNL-0832 (English) ]
"CPU
Dual Intel 64-bit Xeon LGA 771 Quad Core processors, or Dual Core processors, at a Front Side Bus (FSB) of 1333Megahertz, or 1066MHz, with a system clock speed of 333MHz, or 267MHz."
(266MHz geez)
Intel 5000P (Blackford) motherboard chipset.
http://en.wikipedia.org/wiki/Intel_Xeon_chipsets#Dual_processor_Core-based_Xeon_chipsets
BIOS should automatically recognize the new processors.
Sometimes you have to restart the computer, and it may be up to 4 times.
Do agree with Jose though, and you may have to go into BIOS Setup, and set the parameters for the Processor (CPU), manually.
1) What is the sSpec number on the top of the processors?
2) Have you been FOLLOWING Anti-Static Precautions?
3) You are scaring me. What is the reference for the DUCT TAPE for?
4) No post?
Better make sure the Power Supply is good, and I mean test the three main voltages. Do not assume because fans spin, or LED's light, that the Power Supply does not have a weak voltage power rail.
(An economical multimeter around here is $5 to $12)
Does the Power Supply have enough power for TWO QUAD CORE processors?
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Yorkfield-CL.22_.2845_nm.29
Looking through the charts at the Core technologies listed, you can see SOME of the models can use Up To 150 Watts EACH.
(TDP. Thermal Design Point. W = Watts)
Means to me you better have at least a 500 Watt power supply, and I could be seriously underrating.
Better than an intelligent guess,
[Yeah, okay. Maybe 'intelligent' is going overboard, lol! ]
http://extreme.outervision.com/psucalculatorlite.jsp
5) Have the 4-pin ATX +12 Volt power cable attached to the motherboard, (By the 24-pin ATX main power cable connector), and the 8-pin EPS +12 Volt power cable? (Top right corner with motherboard installed in case)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
6) Suggest speaker for BIOS Beep Codes, otherwise you are 'Flying Blind".
7) What kind of Thermal Paste are you using, and how did you apply it?
Not trying to be an ar-se, but if you do not answer all of my questions, do not bother to post back.
Post in a Comment.
Regards,
joecoolvette
Oct 16, 2012 | SUPERMICRO INTEL Eatx Mbd X7db8 5000p Dc...
Can AMD Phenom X4 9650 Quad to use in motherboard Asus M4A78T-E ?
Yes your motherboard supports AMD Phenom X4 9650 Quad. However you need to make sure your BIOS verson is greater than 1503. if not you need to upgrade your BIOS.
Caution: Update your BIOS if its absolutely necessary and at your own risk. Wrong move may spoil your motherboard.
Aug 18, 2011 | AMD 2.3GHz Phenom X4 Quad-Core 9650 AM2+...
How can i use oracle in win 7 platform of i3 processor?and which processor is best core 2 duo or core i3?
Windows 7 Release Candidate was publically released on May 5, 2009. This should be the final release before it goes live later this year. download it, install it in a VM inside of VirtualBox and try to install Oracle on it. There is no Oracle release for Windows 7, so instead grab the Windows 2008 one. The install is pretty straight forward. The only "gotcha" is that if you go to the command prompt, you need to run it as the Administrator, so that all of the Oracle commands will work (lsnrctl, dbca, netca etc...) Really there is not that much to it as it was pretty seemless. So, if you download Windows 7, then you can also download Oracle 11g and start playing with it today!
Here is the second answer
We live in the times where computing power, once available only at the level of super computers, has been made available to the common man. The forerunner in the race, who's probably miles ahead of its competitors is the computing giant Intel. According to the needs of computer users, Intel delivers chips with varying degrees of power and clocking speed. These include the entry level, mid level and high end processors. The latest entry level Intel chips to hit the market are the core i3 processors which are aimed at taking up the place previously held by the core 2 duo processors. The new hierarchy of Intel chips in ascending order of computing power are the core i3, core i5 and core i7 processors. Although core 2 duo processors are slowly being phased out of production, they are still available in the market. In this article, I present a core i3 vs core 2 duo review which may help you decide which one to go for.
Intel Core i3 Vs Core 2 Duo Comparison
A comparison between processors was simple some years ago with a single core processor. All you had to look at was the clocking frequency and the cache size. The entry of multiple core chips changed it all and life became complicated. With dual, quad and even six core processors hitting the market, there are many more factors to be considered than before. Intel's dual core and core 2 duo processors were the first ones to introduce the multicore processor computing power. The quad processors created later have given rise to the quad core vs dual core debate, as well as the core i5 vs core i7 comparison which is something that high end computing market consumers should think about. Prior to that, we only had the 32 bit vs 64 bit processors comparison.
Today, Intel has gone through a lot of designing and planning to introduce core i3 processors that are an improvement over the core 2 duo processors. The following Intel core i3 vs core 2 duo processor comparison will give you an idea about how the i3 processors are different from their dual core predecessors. The two points of comparison will be technical specifications and the only other factor which matters that is performance.
Core i3 Vs Core 2 Duo: Technical Specifications
Like the core 2 duo processors, the new core i3 line of processors, have two cores with many other technological enhancements including an integrated GPU (Graphic Processing Unit). The clocking frequency of the core i3 series of processors ranges from 2.26 GHz to 3.06 GHz. Each processor is endowed with the new line of advanced technologies including Intel developed hyperthreading, Intel virtualization and smart cache technology which makes these chips faster than core 2 duo processors. This is the most important point in the core i3 vs core 2 duo comparison.
The Intel codename for core i3 architecture is Clarkdale. They are based on the Westmere architecture with 32 nm fabrication and a direct media interface (DMI) bus. The socket type used for core i3 processors is LGA 1156 and the RAM type is DDR3. They support mother boards with the following types of chipsets- H55, P55, H57 and Q57.
Let us have a look at the latter processors in the core i3 vs core 2 duo comparison. Core 2 Duo processors come in three types of architectures, codenamed as Conroe, Wolfdale and Allendale. With 65 nm and 45 nm fabrications they are a tad slower and less power efficient than the 32 nm based core i3 processors. The socket used for core 2 duo processors is LGA 775 and they come with a FSB bus. The FSB bus is a lot slower in operation than the DMI bus in core i3 processors.
Coupled with the fact that the i3 processors have a L2 cache size of 2 x 256 kb and a L3 cache size of 4MB, with hyperthreading and smart cache enabled, core 2 duo processors are indeed slower. On top of that, DDR3 RAM compatibility in core i3 processors, compared to DDR2 compatibility of core 2 duo processors makes them even more faster. The price range of Intel core i3 is $100 to $133, which makes them top options in the entry level market.
Core i3 Vs Core 2 Duo: Performance
The technical specifications have made it clearly indicated that Intel core i3 beats its predecessor, core 2 duo in almost all departments. This is but natural as they were indeed designed to replace them. Be it processing speed, multitasking or graphic output, opting for core i3 processors is the logical choice to make!
Hope the core i3 vs core 2 duo processor comparison provided in this article has made it easier for you to choose the right processor for your personal desktop computer or laptop computer. Going for a more advanced line of processors is always beneficial in the long run. You should also check out the Intel core i5 and core i7 processors before going ahead as they offer far more computing power and speed, compared to the entry level core i3 or core 2 duo. Decide on the processor you want according to your usage requirements and of course giving due thought to your vitamin 'M' levels!
Dec 16, 2010 | Intel Core i3 540 306 GHz (BX80616I3540)...
What is the diff. between duel and quad prossessors
Dual processors have two processors insulated as one processor and Quad processors have four processors insulated as one processor.
In other terms, Dual means two and Quad means Four.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | Computers & Internet
What would be my motherboard if my processor is Intel core 2 quad?
Uhmmmm try this one:
Nividia 790i or Intel X38 chipset.
Either of it.
Aug 17, 2010 | Intel Core 2 Quad Q9550 2.83GHz Processor
How many processors in a computer?
There is ONE processor in any computer but each processor may contain multiple cores. Also each processor has what is called "cache" usually named L1, L2, and L3 with different speeds that corresponds to your processors speed. ( i vote go with AMD processors if you need one they are great with price and quality i have a phenom 955 x2 quad core and i LOVE IT 3.2ghz of speed)
May 05, 2010 | Intel Motherboard
Computers & Internet Logo
Alun Cox
