Question about Amana 25" Cu Ft French Doors Bottom Freezer Refrigerator, AFD2535DE
Refrigerator progressively got warmer even with temp at #7. Noticed freezer got very warm, everything melted (ice and all), then refrigerator part got warm. The refrigerator sounds like it's running, but has no coldness to it anymore. Only 2 years old.
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
Noticed my refrigerator is 50 degrees. I raised the temp control but hasn't helped. I raised the freezer temp and that helps bring up the refrigerator temp. Also the icemaker stopped working. I used ice...
Refrigerator
heatman101
Dec 31, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
2 months ago or so, found puddle of water in front of our freezer; about 1 month ago ice cream in freezer became soft. High temp alarm went off a week ago--I've checked the temperature intermittenly and...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 22, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer and Refrigerator Heating up
chances are the evaporator coils (behind the back freezer wall) are icing up and must be thawed out. this is from too much moisture freezing to the coils (door left open in hot weather, drain plugged, or fridge filled before letting it chill for a day empty and on). take back wall off and use warm water or a hair dryer (only until ice melts- do not overheat metal) to melt the ice. soak up excess water from under fridge, too. also check to see if the fan is working.
Jul 20, 2009 | GE PFS22SBSSS Stainless Steel French Door...
At first we though the freezer or refrigerator door had been left open. Ice was melting and dripping in freezer, food was thawed out, but the temperature in the freezer still indicated it was zero +/- 2...
heatman101
Jul 14, 2009 | GE PSC25NGS Side by Side Refrigerator
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator and freezer are warm (Kenmore model 59676509500)
if there is frost on the back wall of the freezer than its iced over (the automatic defrost cycle has failed) turn off the fridge for 18-24 hrs with freezer door open and the ice will melt and it will begin to cool again. It takes a long time for the ice behind the back wall to thouruoghly melt, if it isnt all the way defrosted you will end up with soild ice insead of frost and that will take even longer to thaw Dont forget to rate my solution as solved if I accurately answered your question...Thanks!!
Oct 01, 2007 | Refrigerators
Amana 25" Cu Ft French Doors Bottom Freezer Refrigerator, AFD2535DE Logo
212 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
