Question about Xante Ilumina Digital Color Press Printer
Need to print 11 x 25 80# gloss stock. Can not seem to set up properly. How do I set up for this size banner printing.
  • 24 Answers
You need to set up the page in the printer driver as a custom size, contact me if you still need guidance
Posted on Nov 12, 2010
Brother Fuser Unit not feeding paper
It is possible the gloss stock is gumming up the printer.
Jan 08, 2014 | Brother HL4570CDW Printer
Epson WF - 7520
My EPSON 7520 printer can't print the 1m banner I buy for that purpose, it's new, I design the banner & set up to print, before print when I check for preview it's divided for 4 portion. how can I fixe it? the last size the printer it takes 27cm * 42cm long, but I need to print 27cm * 100cm what can I do? I need help.
Jul 07, 2013 | Office Equipment & Supplies
Do I need a special paper for this printer?
no not necessarily. I suggest you align your printer tray in such a way that it will instantly insert the paper and print it successfully. Otherwise the problem is maybe the unit itself or the drivers..
Mar 09, 2011 | Dell Inkjet 720 Printer
Canon W8400 printing.
Hi Did you get an answer I have the same problem.
Tony
May 24, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Ribbon not printing correctly on new labels have a sato CL412E and we are using the same ink ribbons we always use (premium wax/resin ribbon TRX-55) and we just started using new labels from a new company...
The ribbon / label combination usually doesn't have anything to do with print position of the fields on the label. Is the quality/durability of the print that you are seeing on the new labels the same as before ? With a glossier stock print quality should actually be better. This will at least tell you that the ribbon is correct for the new label stock. Is the new label a different size than previous labels ? That could account for the fields not printing in the correct position if the printer is not calibrating correctly on the new size.
Not sure if this will help but may give some ideas...
Apr 07, 2010 | SATO Cl412e Label Printer
How to set the printer to print banners on continuous paper?
Depending on your printer, you may have to use a 3rd party software that tells your printer to print continuously. If your printer does not support printing full banners without a break in pages you might have to check into getting a printer specially designed for this. Many consumer printers are not meant for custom print jobs, they just use standard paper sizes. If you have your manual, I would refer to that first, but if nothing is mentioned in the manual chances are good that your printer does not support continuous printing.
Dec 31, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Ink not dry when printing photographs
Download the proper drivers from hp.com - DON"T use standard Windows drivers.
When you have the proper drivers installed, you will find an "Advanced" tab in your "Printing Preferences" where you can set "Ink Volume" and "Dry Time".
Try using less ink and a longer dry time.
Also, make sure you're using photopaper that is designed for "INK JET PRINTERS".
(Laser Jet paper won't work).
Any photo that you print on glossy/semi-gloss paper will be wet as it emerges from the printer (especially ones requiring lots of ink).
You could manualy "catch" each one and set aside to dry, which should only take a minute or two.
Professional printers use a special drying powder and timed spray rig when printing on coated cover stock and glossy materials.
Nov 27, 2008 | Office Equipment & Supplies
2600N: glossy paper
Is this HP glossy paper? I would think that laser printers have a hard enough time handling any glossy paper as it is because you run the risk of the gloss burning as the paper goes through the printer so you might have to use the paper recommended by HP.
Here are the specs of the accepted paper.
http://shopping.yahoo.com/p:HP%20Color%20LaserJet%202600n%20Laser%20Printer:1991823169:page=details
Good Luck!
Hope this helps!
Mar 07, 2008 | HP Color LaserJet 2600n Printer
it is a fact of digital print that toner scatter will apear ever so slightly. But it is noticable much more on glossy stock, as there is a high reflectivity, and no micro valleys in surface texture to loose it in..having said that...glossy stock is very difficult to print on with the Ilumina..even on label setting/ auto select for weight and Media switch on(this is the best I have been able to achieve)
Sep 26, 2007 | Xante Ilumina Digital Color Press Printer
49 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
