Question about Windchaser WCUFLTI Tower Fan
I'm getting a squeaking noise from my Windchaser WCUFLTI fan when it stands upright. If I lean it against the wall, the noise stops. I'm in the process of dismantling it, but can't get the back cover off. So... any ideas?
Not sure on the squeaking. Mines squeak to on the low and medium speed, but not on high speed. As for the cover, remove the three 'visible' screws. There are two screws in the handle, but you have to remove the plugs that are hidding the screws. Use a thin flat blade screw driver to pry the plugs. Then, the screws will be visible for removal.
Once the all the screws are off from the back cover, using a flat screw driver depress the tab above the handle; then, gently '****' downwardly (assuming the fan is standing) to remove the back cover.
Posted on Jan 27, 2011
My fan is swaying and is very wobbly. I'm trying to figure out how to fix it
First, start at the top and make sure the hanging bracket is tight against the electrical box. If your fan has a downrod, make sure the set screw is tight. Next, check the blade holder and make sure they're tight. Then check the blades screws. If one of the blade holders are bent, even a little, they would need to be replaced. And lastly, check the blades to see if they are warped. If so, they would need to be replaced.
May 14, 2015 | Windchaser WCUFLTI Tower Fan
Machine wont stay standing bag and handle falls down
the detent is broken. Usually only costs about $8 for the part and maybe 15 to put it in, but it depends on the make/model. Or you can just lean it against the wall...
Nov 08, 2013 | Riccar 8955 Upright Vacuum
Stuck on standby
windchaser upright fan stuck on standby,no remote how to work without remote?
Aug 09, 2012 | Windchaser FTR163 SensorFan Stand...
How oil goes in the primary for 03 Buell firebolt xb9r
Stand the bike upright (use a swingarm stand or lean against a wall), then poor one quart of oil (I recommend Harley Formula+) into either of the windows on the primary cover. The oil should be just covering the bottom of the gear visible in the larger window.
Aug 19, 2011 | 2003 Buell Firebolt XB9R
How can i get a manual? wcuflt1 and remote control
Windchaser messed up the link to the manual. Here's the correct link (the link is case sensitive):
http://www.windchaserproducts.com/manuals/WCUFLTi_manual.htm
Oct 22, 2010 | Windchaser WCUFLTI Tower Fan
Where can I get a part for my Windchaser 16" osilating stand fan, model IVS182. It stopped osilating and needs the small part that helps it osilate. Don't know what it is called.
Check with the manufacturer, they should be able to get you the replacement part. Maybe they show a diagram online with names of parts that can help you name it, so they can send you one.
Hope this helps. Good luck!
Jul 30, 2009 | Windchaser (IVS182A) Stand (Pedestal) Fan
It does not stand up straight
the plastic locking mechanism to keep it upright is broken. It can be fixed, but not sure it is worth fixing. I know its a pain to lean it up against the wall all the time, but the cost for replacing the part is not worth the expense in my opinion. Good luck!
Jul 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Windchaser WCUFLTI Tower Fan Logo
519 people viewed this question
Top Windchaser Dryers Experts
Ian Summerfield
Ian Summerfield
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
