Question about Emerson Microwave Ovens
Emerson MWG111SL grill combo micrwave......,grill works everything comes on like its suppose to but no heat,it has not blowed the ceramic fuse.what can i do????
  • 185 Answers
SOURCE: Emerson Mwg9111sl microwave blows 20 amp internal fuse instantly everytime.
check your thermal fuse its about 2 inches long white on the outside black on the inside it has 2 wires going to it check for
cotinuity becareful of the capacitor you need to disapate that first by touching the two teminals together with a screw driver
Posted on Apr 01, 2008
  • 958 Answers
SOURCE: Bought Emerson MWG 9111SL Combo
it should have it inside the box when you bought it new. if there is none, go back to the place where you bought it and they would be glad to give you a copy of the customer's operating manual. i hope i was able to help
Posted on Jun 24, 2008
  • 86 Answers
SOURCE: Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Posted on Dec 28, 2008
SOURCE: my sanyo microwave grill combo ,microwave wont heat food
I have a Emerson combo. It wont heat
Posted on Mar 12, 2009
  • 3 Answers
SOURCE: Microwave oven blowing 20 amp ceramic fuse
Chances are if the varistor fails, it fails drastically causing a short circuit across the supply. It will sit across the supply (it will look like a thick ceramic capacitor) and you can check for continuity after isolating that at one end. If it shows low resistance (it should show almost open circuit with a Digital meter), replace it.
It need not be the culprit. If you are familiar working with High voltage circuits ( they are lethal inside a microwave ovens as the current capability is high here), you can discharge the doubler capacitor and isolate the high voltage diode to check for shorts in the HT area.
Posted on Mar 18, 2009
How do I use the grill function on my new microwave?
I've had an Emerson microwave/grill for about 5 years now and love it!! To use the grill function you just hit "grill/combo" then hit the buttons up above the grill/combo button for however many minutes or seconds you want, then hit "Start" button. make sure your using a metal dish.
Feb 20, 2016 | Emerson Microwave Ovens
Plugged in my Emerson MW7300W. Light works, won't cook
there is a thermal (white ceramic) fuse located right under the cover on the top of your microwave replace it.
an electronics part store should stock it.
Feb 01, 2010 | Emerson MW8777W Microwave Oven
I was heating up some left over for 1 min. and before completion the microwave just stopped. I have tried all of the usual stuff to get it going again. It is not the electrical socket nor the fuse box...
It could be as simple as a blown fuse inside the unit. They are usually ceramic type fuse not glass, so you need a meter to check it or you can try to replace it and see if it fixes it. Please use only a fuse of the same type and amps! The unit may blow the new fuse, which would indicate a short inside... you''d need to call a repairman. Lastly check your warranty dates, if under a year you may have some coverage. Hope that helps.
Geno
Dec 06, 2009 | Emerson Microwave Ovens
Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
May 23, 2009 | Microwave Ovens
Mar 18, 2009 | Microwave Ovens
Emerson Microwave (mw8992rd) not heating up
I have replaced the main fuse on this model. Though blown main fuses are common in this model, it will not even turn on when they blow, so your problem is most likely NOT a blown fuse. I had heard of your problem so, when replacing the main fuse inside one, I looked for additional fuses and saw none. The store was wrong. Even if it were a fuse, the security Torx screws mean that you couldn't replace the fuse anyway.
This microwave seems to have been haphazarly been recommended by Consumer Reports, but it is terribly unreliable. The turntables break when popping popcorn, the main fuse repeatedly blows, and they also stop heating.
Oct 19, 2008 | Emerson MW8985W Microwave Oven
Apr 01, 2008 | LG LTM9000 Microwave Oven
No power from Whirlpool.
IF YOU HAVE THE MICRWAVE PLUGGED IN AND THE CIRCUIT BREAKER TRIPS IMMEDIATELY WHEN SET,
CHECK THE DOOR HOOKS THAT TRIP THE DOOR SWITCHES. BOTH SHOULD BE SPRING LOADED. THERE SHOULD BE TWO HOOKS ON THE DOOR. IF O.K., CHECK THE DOOR SWITCHES. THERE ARE AT LEAST THREE. IF ONE OF THEM IS SHORTED CLOSED,
THE MONITOR SWITCH WILL CAUSE A DEAD SHORT ACROSS THE FUSE. THE FUSE MAY BE HOLDING BETTER THAN YOUR CIRCUIT BREAKER.
Mar 21, 2008 | Whirlpool MH1150XMQ Microwave Oven
Emerson Microwave MW8115SS
I bought my emerson microwave 3 years ago model# mw8115ss from walmart and have had all the problems that everyone has talked about and I thought about throwing it away until I thought about one small detail, the FUSE. China uses junky glass fuses that burst instantly with a slight power outage, door slamming to hard, moving it around, and of course constant use like myself always heating up water for bottles. I took the back of the microwave off and walla!!! a blown fuse, but wait!!! dont buy another glass fuse!!! go to your local home depot and get the ceramic fuse for microwave ovens!!! they are $2.83 at my local home depot. I replaced the junky glass fuse with the ceramic one and it has worked perfectly for six months now.
DONT let someone tell you that you cant replace a glass fuse with a ceramic one because they are full of boloney. My microwave did all kinds of things, it wouldnt turn sometimes, it would come on by itself, it would beep for no reason, turn but not heat up, you name it I had the problem. When a fuse starts to go out it can make your appliances do some strange things, check the fuse and replace it with a CERAMIC one and I promise it should eliminate your problem.
Apr 22, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
