Question about Stairmaster 3400CE Upright Exercise Bike
Display won't light up when i start peddling, could it be the battery
  • Stairmaster Master
  • 914 Answers
It most definitely could be the battery. I would start with checking for at least 6 volts DC output from your battery.
Video about How to Test Battery
Posted on Jun 20, 2014
Break light won't come on when I step on peddle only 3rd light fuse and lights are good
check your wires and make sure everything is hooked up and make sure all wiring is cover and not bare
Oct 12, 2012 | 1994 Cadillac DeVille
When I hit the break peddle, the break lights won't come on
there is eather a swich under the dash that is out or there could be a fuse thats blown.
Sep 04, 2012 | 2004 Dodge Neon
My 1988 dodge Dakota 3.9 3 speed automatic 2 w Dr.idles rough and sometimes dies at a stop light and won't restart unless I put the gassed peddle to the floor.when it does finally start I have to keep...
Replace your hose going from intake to brake booster ( vacuum leak) check all other hoses also. Clean the throttle body. And a tune up probably wont hurt either.
Jun 09, 2017 | Cars & Trucks
Proform GR 80 won't turn on even after new batteries, how do I fix?
On mine, I found that the battery contact springs on the inside of the control head (not the ones on the battery lid) were flattened out and were no longer making good contact with the batteries. I used a small hook to stretch them out a little so that they could make contact. As soon as I put the batteries back in I saw the display light up and now the bike works normally again.
May 17, 2012 | Exercise & Fitness
Tail lights won't go out, even when van is off. Help
Look under the dash, follow the brake peddle untill you find a switch, it's the brake light switch, try adjusting it (it moves in and out of a plastic insert, may take a little pressure to move) there should be two wires that connect to the switch, when the brake peddle is not in used the switch breaks the circiut, push the button on the switch, brake lights should go out, if not, check for power, replace if nessasary
Aug 12, 2011 | 1999 Ford Windstar
I ran my jeep radio until the battery died. I jumped it and it started but the Electronic Throttle Control light came on and when I push the gas peddle nothing happens. I replaced the battery and still...
same thing happened to me last night. Looking for an answer online like you. If you find one, please e-mail me at brian.f.mckone@medtronic.com. thank you very much.
Oct 20, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Stairmaster 4400 display went dead and now there is no resistance to the peddles and the display doesn't pop up at the start of excercise.
Investigate the battery on this unit. The machine uses a 6volt battery. If there is no power, there cannot be any resistance.
Sep 24, 2010 | Stairmaster 4400CL Stepper
Can't get car out of park!!
This may seem like a silly solution but it's worth a try if it gets you out of this jam. I believe the Kia has a safety feature where it won't let you shift the car out of park unless the break peddle is fully depressed. Try stomping on the break peddle while you start the car. Then see if it will let you shift out of park. If this doesn't work try pumping the break peddle a few times and try it again. If this doesn't work check the fuse box. Maybe the fuse for the actuator in the gear shift lever that lets you take it out of park is burnt out. I hope this helps you out.
Jun 03, 2009 | 2006 Kia Optima
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Brake lights
under the brake peddle is a switch. Lift the brake peddle upwards and you will see that the brake light goes out [requires two people; one to hold the peddle up, other to view the brake lights]. Restrengthen the spring tension on the brake peddle.
Should the lights remain ON after you lift the brake peddle up, unplug one of the wires to the brake peddle switch. At this point, the brake lights should be off. This basically will determine whether your switch is shorted or is just a peddle pressing down on the switch due to a bad spring.
Oct 15, 2008 | 1991 Honda Accord
Stairmaster 3400CE Upright Exercise Bike Logo
162 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
