Question about InFocus ScreenPlay 7205 Multimedia Projector
Infocus projector My picture has split into two halves with the bottom part at the top and visa versa
  • InFocus Master
  • 5,568 Answers
The settings of the video section of the computer probably need to be adjusted; this is a synchronization problem.
Check the Infocus website for clues.
Posted on May 27, 2008
Picture is cut off top and bottom (Infocus 7210 projector)
try different ratios, also reflash firmware and lastly try new cables.
Jul 14, 2010 | InFocus ScreenPlay 7210 Multimedia...
Dark side of screen
the light tunnel has collapsed and needs replacing. the part is inexpensive and relatively easy to replace. if you can get the part from infocus or an authorized service center (part # 306-0095-01), remove the top (4 brass screws and 4 silver screws on the bottom, 2-3 silver screws on the back), next to the lens is the colorwheel. remove the 2 black screws on the colorwheel base, 2 black screws on the metal tunnel frame side, remove the tunnel glass. replace, and reverse the instructions to put it back together.
Aug 15, 2009 | InFocus ScreenPlay 4805 Multimedia...
Picture on screen is cut off
reset the settings to factory default. if that does not clear it up, there is a sync issue. try a different cable. otherwise, there is a problem with the main board.
Jul 08, 2009 | InFocus LP 340B Multimedia Projector
Words on screen can be seen
In the picture there is a check box labeled "overscan"
Uncheck it.
If that doesn't work... What input are you using? This can also happen with the incorrect DVI or HDMI to M1-D adapter. If you are using the M1-D computer input try using the composite input. If you are using the computer with a computer source try changing to the external monitor screen resolution or aspect ratio.
Apr 22, 2009 | InFocus X1 Multimedia Projector
INFOCUS Screenplay LCD projector...
Hi there
I take it the Projector is ceiling mounted ?
If this is the case check that it is installed with the lens of the Projector in the facing straight to the middle of the screen or try adjusting the bracket's swivel head to move it a bit - should do the trick !
May 10, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus X1A Projector
This is a very common issue with the Infocus projectors. Sounds like the mirror tunnel that sits right behind the Color Wheel and concentrates the light source onto the DLP chip. This tunnel which is shaped like a small prism is very fragile and can "fall apart" over time. Some have attempted to try and remove the tunnel and repair with limited success. Otherwise you may either need to send the unit in for repair or find a dealer who can order the part for you.
Here is another who had the same issue;
Mar 14, 2008 | InFocus X1 Multimedia Projector
Infocus LP240 Projector
The bulb won't do that. What you're describing sounds like a light tunnel failure.
Feb 05, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Black lines are appearing on the top and bottom of projection,.
try factory reset in the menu. if that doesn't help, it could be the light tunnel, but infocus doesn't have parts for the lp3xx series anymore.
May 16, 2007 | InFocus LP330 and LP335 Replacement...
InFocus ScreenPlay 7205 Multimedia Projector Logo
127 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
