Question about DeLonghi DCF212T
Electrical contact works but it doesn't heat the water up.
It is my first time using it, I brought it from USA and it is not working at all!!
follow this steps and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electric cord and check the thermostat .
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jun 11, 2013 | Black & Decker Irons
Waffle iron not heating
see this steps and fix it. God bless you
f the appliance does not heat, make sure that power is on at the outlet and test the electrical corrd , replace it if needed. If this doesn't work, disassemble the unit and test the heating elements.
If the appliance does not heat to the proper temperature, check the thermostat contacts. Some cooking appliances have an adjustment to reset the temperature ranges; you'll need the owner's manual to do this job.
Oct 15, 2012 | Hamilton Beach 26500hb Waffle Maker...
Iron will not heat up
See the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 23, 2012 | Unknown LAURASTAR PREMIUM S3 Ironing...
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
I have an Atwood electronic ignition 6 gal. water heater. When I flip the switch to light, I can hear the ignitor sparking but there is no ignition. How can I isolate the problem?
Use a multimeter or test light for 12volt DC, and check at gas valve for 12 volts when it is trying to ignite (you here/see it sparking ). If no 12 volts to there, it will not ignite because no gas is flowing through valve. Try removing the connectors on the circuit board/module ( with switch in off position ) and cleaning the board contacts with a pencil eraser, and spray WD-40, or preferably an electrical spray/contact spray on connector contacts and retry. Board, or module may be located outside , or inside on top of tank, depending on what year and set-up. If that doesn't work, there is a small cut-out enclosed in plastic sleeve right near pressure relief valve area, that looks like a resistor that may be faulty. Remove it from the circuit and try it then. Simply pull the wire off at thermostat, pull that out of the sleeve by disconnecting it from the female spade connector, then put female spade where it used to be on thermostat terminal. If it works, buy a new thermal cut-off. If all that is done and tried, and still doesn't light, replace module.
Aug 09, 2011 | RTO Atwood Water Heater - 6 Gal LP
Our Dualit toaster doesn't work. The red light doesn't work. I have changed the fuse in the socket with a working one. The timer turns normally. Yet none of the heating units heats...
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
Jun 12, 2011 | Dualit Vario 3 Slices Toaster
Dishwasher not drying dished with any heat source. Dishes washed in cold water.
Most dishwashers are plumbed to the hot side of the hot water side of the faucet. This should provide hot water for washing the dishes. Perhaps this dishwasher was plumbed to the cold water side by mistake.
Most dishwashers have a heating coil most of the way around under the bottom sliding/rolling dish rack. The heating coil may not be working, which would be consistent with the dishes not drying at the end of the cycle. Possible causes include incorrect setting selected on control console (push buttons) or timer, heating coil disconnected from electrical source at one end or both ends, faulty control circuit inside the timer, faulty wiring between the timer/control circuit and the heating coil, burned or pitted contacts in the control circuit.
May 23, 2011 | Dishwashers
I have a electrical smoke coming from the back of the machine when it is heating
The machine have a water leak and the water make an electrical contact so the smoke. You should solve the leak before something will meld from the electrical short heating produced.
Dec 12, 2009 | Breville Die Cast 800ESXL Espresso Machine
Maytag alantis MAV 9600
hi thanks for the question re set the water level control to see if it will add more water if it doesn,t it could be a bad water valve check that thanks the appliancedoc
Sep 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Espresso Machine Stopped Working
Mine stopped heating (pumped only cold water) and when I opened the top of the machine I noticed that the blue electrical cable to the thermal block assembly (probably to the thermal fuse, but I an not sure about that) corroded and was loose. I fixed the connection and since then the machine heats perfect.
May 12, 2008 | Breville ESP8XL Espresso Machine
DeLonghi DCF212T Logo
32 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
