Question about JVC Televison & Video
JVC LT-32DT8 PR LIst Empty Error
I was just wondering if you would be able to help. Currently having problems with the stated model. Everytime it switches on to Sky it reverts back to a DTVsetting and says PR List Empty and every time you switch it back to Sky it goes back to the PR List Empy sign again and flashes then between terrestrial and DTV. It also sometimes flashes 'Start Shipping'. Any idea what the problem is? Or how to reset the TV?
Many Thanks,
Lewis
  • poppydaisy Dec 08, 2008
    My tv has the same problem i've not got sky but the tv keeps saying pr list empty. I have tried to re-install but it just comes up pr list empty again
4 Suggested Answers
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
  • 122 Answers
SOURCE: Samsung LE40R
try to change the stantard from the channel setting menu(bg-dk etc.)
Posted on Jun 06, 2010
gopakumarg43
  • 74887 Answers
SOURCE: JVC LT-32DA20J lcd TV. Unable
Hello
Check the antenna connection at antenna socket of the TV for any loose. If there is any loose contact, the signals get into the tuner section of the TV will be very weak, resulting no colour to picture. If picture and sound is there, and there is only fault with colour, surely it will be due to weak signal strength. Try to reorient the outdoor antenna; if used. If cable is connected, contact the cable provider and ask him to measure the signal strength at the end of cable connected to to TV. OK.
Posted on Jul 26, 2011
Skycom pin help
You can ask here... http://contactus.sky.com/uk/sky-tv/problems-with-sky-tv
Jul 08, 2014 | Televison & Video
How to take screenshot with Panttech Sky Vega Lte
Try to push the power button and the home button at the same time! (not actually holding it, just try to do it rather quickly) If you are running IceCreamSandwich it should work (my case).
Hope it helps mate!
Jan 25, 2013 | Pantech Sky Vega Lte M Im-a810k A810s...
Comet hitachi tv loses tuning / untunes everytime switched off
Vestel make the power boards... its unlikely that they will help. Your best bet is ebay, look for 'main board'
Aug 28, 2017 | Televison & Video
Hi I've recently bought a UMC 40" TV (model: M40/74G-GB-FTCU-UK) and everytime I try to tune it, it just says there is no signal and no channels are found. Everything is connected as it should be....
strange it sounds like there could be more of an issue with the skybox but if you have any RCA cables plug them in and use AV1 or AUX on the tv set however if it has HDMI then plug in a HDMI cable to and from the skybox otherwise check on the back of the skybox and see if there's a channel the TV must be set to
Aug 22, 2017 | Televison & Video
Cant find the make and model number to program the sky remote to. even the manufacturer Konka doesn't have the model number of my tv....help!
Hi Dave,
I am also unable to tell you the model number of your TV. The make however is Konka as you have already stated. If you don't have a model number, the best thing to do is try generic codes Sky give for Konka.
0065 0584 0399 0742 0446 0246
If these codes don't work or you need instructions on programming your Sky remote, please post back for further assistance. Please include as many details of your TV as possible, e.g. Screen size, type (CRT / LCD / Plasma) and anything else about it's appearance that may help me to identify the model number. I also assume you have checked on the back of the TV - the model number is often printed there on a sticker.
Hope this helps - please post back if I can be of further assistance.
Regards,
BElectric
Dec 16, 2010 | Televison & Video
I am looking for the Sky remote code for a Sony KDL-40V2000 TV can you please help.
Sky don't have a specific code listed for this model yet, so the first thing to do is try the Generic Sony codes first. These are:
1679, 1533, 0678, 0681
These codes are for a "Rev 8" Sky remote. If the above codes don't work or you need further assistance, please post back and I will investigate further. When posting back, please state which Sky remote version you have and whether it is also Standard Sky, Sky+ or Sky HD. The version number can be found on a sticker inside the battery compartment. RC1600/00 is the old original. Newer remotes will also have either "Rev 4", "Rev 6" or "Rev 8" on the sticker.
Please note that Sky remotes wont work with all TVs. I've been informed that a new revision of the Sky remote is due soon but I have been unable to verify this.
Hope this helps. Please post back with the information requested above if you need further assistance.
Regards,
BElectric
Nov 21, 2010 | Televison & Video
Cannot connect to sky router
sometime this would because your router is thinking that your phone is a hacking device and so it will not allow full connection so if you put a password on you router it would probily fix your problem
Jan 21, 2009 | Belkin Wi-Fi Phone for Skype - Wireless...
I was wondering what is the typical ideal set up in terms of picture settings to obtain the best picture from my 46" samsung 6 series. It is currently connected to my sky box (not HD)through a normal...
If you are not connected to HD, pixelation can easily occur, especially if you are using an analogue connection. Here is a list, from best to worst, of how you should connect the video on your system.
1) BEST - HDI cable between the TV HDMI in and the sky box HDMI out. This is a full bandwidth digital audio and video connection.
2) BETTER - S-Video between your TV and sky box (with L & R audio)
3) GOOD - Component Video with L & R audio
4) STANDARD - single video cable (yellow) along with L & R audio
5) standard coax
These are listed, as stated, from best to worst quality. If you are not using a digital connection (HDMI), then pixelation can be expected.
Sep 03, 2008 | Samsung Televison & Video
Hi,i am wondering if you could help me.I am having trouble programing my sky remote to operate my tv.Every code that i have tried does not work.I have tried sky themselves,my tv manufacturer and have...
have you tried pressing the interactive button--a-z--thenset up your sky remote and press selectwhen the screen appears.
choose the model t.v that yours is andthen select a model NUMBER then follow the steps that are shown
Apr 03, 2008 | Televison & Video
Televison & Video Logo
395 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
