Question about QSC ISA 300Ti Amplifier
I am using this amp for an intercom system. I have 24 speakers hooked up in a train fashion but I am unsure on the back of the amp where my black and white speaker wire should go, can you help me? I have everything else hooked up correctly. Dave
  • Scott Frye
    Scott Frye Oct 04, 2010
    Do you mean "series" connections when you say train?
    And, are they 8 ohm , 4 ohm or line-driven speakers?
    Thanks
    Champion:
  • 211 Answers
It's depending on which speakers you are using. If you're using 100Volt speakers you can connect them on ch.1 between 0 and 100 volt. Then you are using only ch.1.
Regards,
Gerard
Posted on Oct 05, 2010
4-8 ohm output
it is load resistance. set the amplifier switch to the resistance ( X amount ohms) to match your speakers. Although running 4 ohm speakers at the 8 ohm setting is louder, it will hurt your amp
most home/semi pro speakers are 8 ohm, while car speakers are 4 ohm. If you are doing a multi speaker pa/intercom install use your formula to calculate total load is 2 8 ohm speakers in parallel are four ohms . express them as fractions and add the denominator ie:8/1 +8/1 = 8/2 or 4/1 or 4. now connect that in series (add the top numbers)with another 2 speakers in parallel and you get back to 8 ohm load. repeat the same process over and over and you can hook up to 32 speakers to the amp without needing the 70 volt tap. hope this helped.
Mar 18, 2014 | TOA Electronics A912MK2 Amplifier
I have a toshiba DKT 2020 SD and I need to change the time. Please help!!
Depending on the type of system you have powering the 2020,this should take care of it.
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds - enter a leading 0 for any single digit entered,
press Redial,
press Speaker.
This must be done at extension 200 - usually the receptionist phone.
For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker
Mar 18, 2011 | Toshiba DKT-2020 Corded Phone
How do you change the time on the phone system ?
Toshiba 2000 series phones can be used with a lot of different Toshiba systems. With that in mind, this should cover your system.
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered, press Redial, press Speaker.
This must be done at extension 200 – usually the receptionist phone. For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker.
Jul 01, 2010 | Toshiba DKT2010SD Phone
DKT-2020 Corded Phone (dkt2020sd): How do you change the display time on the DKT2020-...
press Redial,
press Speaker.
May 09, 2010 | Toshiba DKT-2020 Corded Phone
Need to fix date and time onToshiba DKT2020-SD
Depending on the type of system you have powering the 2010,this should take care of it.
press Redial,
press Speaker.
May 07, 2010 | Toshiba DKT2010SD Phone
How do I change the time on an office toshiba dkt2010-sd telephone. I looked in the online manual and cannot find the answer. Thanks
There a few different types of systems that work with that phone. I'm guessing that its either going to be a dk 40i or dk 280.
Leave the handset2.gif on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered, press Redial, press Speaker. This must be done at extension 10 – usually the receptionist phone. For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker.
Nov 07, 2009 | Toshiba DKT2010SD Phone
NEED TO CHANGE TIME ON THE PHONE...HELP
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered, press Redial, press Speaker. This must be done at extension 10 – usually the receptionist phone. For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker.
Nov 06, 2009 | Toshiba DKT-2020-SD telephone
How to wire a new contactor for a train xL1000 HEAT PUMP
There should be 6 terminals on the contactor.
2 for 24 volt AC controller -- these are small thermostat type wires
2 for line (supply voltage) -- usually red & black (220 volts)
2 for load -- color? -- these go to the compressor/fan circuitry
The contactor should be marked as above in some fashion.
If the above doesn't apply, let me know how the contactor is labeled and we'll figure it out.
Charlie
Aug 21, 2009 | Heating & Cooling
RX-V661 Receiver
your receiver has zone 2 output which is operated independently of the main reciever. so you can have a dvd playing inthe main reciever and the tuner playing over the intercom. read about it in your manual page 89. in will hook up to 2 RCA jacks in the back Zone 2 out.
Dec 29, 2007 | Yamaha RX-V661 Receiver
Need to set my time on my phone
I think this feature is dependent on your system - the phone display is in agreement with the entire network. Check to see what system your phone is on - ours is a Strata DK-280 - and then search Google to find a total solution to changing time.
Dec 07, 2007 | Toshiba DKT-2020 Corded Phone
66 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
