Question about Nikon COOLPIX S570 Digital Camera
After upgrading to MAC OS 10.6.4 I cannot download pics from my Coolpix S570 into iPhoto '09. I have latest version of Nikon Transfer (1.5.2). iPhoto gives error message files are unreadable. Icon for camera shows iPhoto but picture frames are blank. Thanks, Bob
  • 1 more comment
  • bobamblad Oct 05, 2010
    As originally stated I already have Nikon Transfer 1.5.2, the latest version. Nikon.com/drivers mentioned in your reply as a solution is not a valid URL.
    What's your next suggestion?
    Bob
  • bobamblad Oct 06, 2010
    So, any more great ideas for my $15 bucks?
    Bob
  • bobamblad Oct 16, 2010
    None of the above solutions worked or were applicable. I solved problem by purchasing a digital card reader. The pictures downloaded OK into iPhoto. After reformatting the SD card in the camera, I took several test pictures which also downloaded OK. Problem must have been in the card. Thanks for the help.
  • Nikon Master
  • 19,396 Answers
Hi Bob.
Problem is a well known issue between Snow Leopard and several cameras. You will need to play with installed software and setting. Here different work around.
Temprarily turn Bluetooth off. See here.
Try installing the following: Adobe - Adobe Camera Raw and DNG Converter
If that does not work, try setting the Mac with camera mass storage in USB mode, I quote a testimonial from this forum:
"I found a workaround/solution for my issue. My camera has two USB modes: "Mass Storage (USB DIRECT-PRINT)" and "PTP (PictBridge)". I've always used PTP with my mac and everything has been fine. But apparently iPhoto on OSX 10.6 no longer likes PTP (keep in mind that Image Capture handles the camera fine in PTP mode). When I switched it to Mass Storage mode, it works fine now in iPhoto."
If still no luck, change preference to image capture, I quote:
"1) ejecting the "camera name" from the desktop. I had to do this step because I had tried to connect to iPhoto and it didn't work.
2) Going to iPhoto prefs and selecting Connecting camera opens "Image Capture" - not iPhoto.
3) Connecting the camera again. Image Capture opens.
4) In image capture selecting from the bottom left hand corner Connecting camera opens "iPhoto"
5) iPhoto magically opened and I could import and delete."
If still no luck, do a new upgrade using a combo installer, see here.
If all that does not work, contact Apple, camera is supported by Snow Leopard and they must find a solution. See: Apple - How to Contact Us.
Ensure that you try all workaround, there is no "one for all Macs" solution for this problem.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Good luck.
Ginko.
Posted on Oct 06, 2010
  • Nikon Master
  • 17,130 Answers
This can be a software mismatch and so I think can try to upload a new driver for MAC supporting your version.
Uninstall the present one and reinstall, then connect your Nikon and try again.
Please try this link for support to down load:
www.support.nikonusa.com/app/answers/detail/a_id/61/~/?current-versions-of-nikon-software www.NikonDrivers.DriverPlex.com
Posted on Oct 05, 2010
  • 10,865 Answers
Hello Bob. Go to Nikon.com/drivers and download the driver that is especially written for your camera and your MAC. This is a free download. After you download this new driver, run it. Then you should be fine. Joe
Posted on Oct 04, 2010
I have a nikon coolpix L100 problem. I have always been able to download pictures to my mac book using IPhoto. However, for some reason my camera isn't showing in the source. It shows briefly when
Do what the pros do to avoid this very problem...use a card reader to download to a folder you create on the desktop. Once there, you can send the pics to iPhoto.
Nov 10, 2011 | Nikon COOLPIX L100 Digital Camera
Nikon Coolpix S10 setting up software
You need to have a mac compatible driver installed for the camera as that could be one of the reason its not accepting the command.
Aug 22, 2008 | Nikon COOLPIX S10 Digital Camera
I recently had The Applestore install OS X 10.5.8 on my computer and for some reason I can no longer import pics from my Nikon Coolpix 4600 to iPhoto. Can you help?
Create a folder on your desktop. Using a card reader, drag and drop your pics into that folder. From there, you can transfer the pics to iPhoto.
Jul 27, 2011 | Nikon Coolpix 4600 Digital Camera
We cannot get our images off of the Nikon Coolpix S570. I have a Mac (OS 10.4.11) - am linking with the USB standard cable that comes with the camera. The Mac can see the Camera in devices (about this...
I am not sure if I can help but what I would suggest is first of all disconnect the camera from the mac and then if you have iphoto go to preferences and make sure that iphoto is the application that is activated when the camera is plugged in. Then close the preferences. Now connect the camera to your mac. If you do not have iphoto you can use image capture which is in the applications folder. Hope this helps.
May 27, 2011 | Nikon COOLPIX S570 Digital Camera
Does nikon coolpix S10 work with mac os 10.6.4?
The camera doesn't care what computer you have, let alone the version of the operating system.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use iPhoto or any photo cataloging program.
The current version of Nikon Transfer only supports 10.6.2. ViewNX2 does support 10.6.4. Once the pictures are on the Mac, you can continue using iPhoto, or use ViewNX2 (or both) to organize and catalog your pictures.
You can download the current versions of all (free) Nikon software from
http://support.nikonusa.com/app/answers/detail/a_id/61
Nov 15, 2010 | Cameras
I have a new macbook pro and when I plug in my nikon coolpix, I cannot download my pics?
You can download the mac drivers for your cam to work from here:
http://www.opendrivers.com/driver/248268/nikon-transfer-1.0.2-full-version-mac-os-x-10.3.9-and-10.4.11-free-download.html
Aug 10, 2010 | Nikon Coolpix S210 Digital Camera
Iphoto won't recognize nikon coolpix s570
Use a card reader instead of the camera and download to a folder you create on your desktop. From there, you can import to iphoto.
May 04, 2010 | Nikon COOLPIX S570 Digital Camera
Can't transfer from camera to mac
Use a card reader to download to a folder you create on your desktop. From there, you can import to iphoto.
Feb 12, 2010 | Nikon Coolpix 4800 Digital Camera
Nikon COOLPIX S570 Digital Camera Logo
265 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
