Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Unable to read SD cards
I had an SD card in an Imagemate SD and a SanDisk Cruzer enterprise simultaneously connected to my Lenovo ThinkPad T61 with Vista Business, SP1. Now, no matter what I do, including deleting the drive letters out of the registry that the Cruzer was using, I am unable to read the SD cards. Thus I can’t transfer photos from my camera to my PC. The camera is a Casio. I’ve also tried connecting the Casio directly to the computer through a USB cable and no luck.
What do you suggest?
  • 5 more comments
  • emersonm May 28, 2008
    Thanks. There was no entry marked SD card, no duplicate, no entry for anything except the hard drive. I agree that the drive letters got mixed up, especially since the cruzer grabs two of them, but that doesn't help undo the damage.
    Did that long before I posted this problem. No help at all. Sorry.
    Great suggestion. I didn't know that the restore feature existed. Unfortunately, restore won't let me undo SP1 (wish I hadn't installed it!) and so I can't restore the system before the problem occurred. You should also know that if I try to boot the PC with the card installed, the hard drive won't work. Depending on what's going on, having the SD card in the USB port may send the PC into a loop.
    Yes, both the cruzer and the SD cards work fine on another PC. I borrowed a friend's PC to get the photos off several weeks ago, but now I have new ones.
  • emersonm May 29, 2008
    No, thank you. I'm not comfortable sharing data with someone I don't know.
  • emersonm May 31, 2008
    I didn't have anything plugged in. Vista only allows a restore back a couple of days and I need to restore the system back a couple of months. I uninstalled SP1 and another hotfix to no avail. I could really use an informed recommendation, not just random guesses. My suspicion is that there's conflicting information in the registry somewhere, but I can't find it.
    Yes, of course I know I can do that. However, I'm concerned about all that it would wipe out. I was hoping for a more specific solution.
  • 3,037 Answers
Try doing a system restore first on your computer by going into your Control Panel inside Performance and Maintenance and set this back to a day before this problem occurred. This should fix it and will keep all files, pictures and anything else you put on the computer after the restore point and it is also reversible. Let me know how this goes and if it doesn't work, then I have other options that we can try. good luck and please let me know of any questions or concerns that you may have with this
Posted on May 27, 2008
  • Benjamin Patri
    Benjamin Patri May 30, 2008
    so the system restore won't run or an error comes up, unplug the unit that is causing the problem and try restoring the system
  • Benjamin Patri
    Benjamin Patri Jun 01, 2008
    Are you sure that there aren't any restore points at a random day a few months back, the computer may make one every once in a while and it would be worth checking out
    Master:
  • 555 Answers
Plug the SD card into your computer.
Right-click on "Computer" and select "Manage"
Select "Disk Management"
Find the entry for your SD card (it might have no drive letter, or a duplicate drive letter). Right click on the SD card entry and select "Change Drive Letter" Change it to an available drive letter.
Your card should now be accessible.
  • Matt Jurach
    Matt Jurach May 27, 2008
    I'm guessing that the drive letters were mixed up by the U3 virtual-CD-Rom nonsense on the Sandisk Cruzer.
  • Matt Jurach
    Matt Jurach May 28, 2008
    There's actually three devices in this problem matrix: the Cruzer, the SD card, and the Imagemate.
    Sorry to be so pedantic, but when you say that the SD card worked in a friends computer, did you plug it in there using your Imagemate, or through some other method? (I want to figure out if we know whether the Imagemate is functioning correctly).
    Also, you've said that if you boot with the SD card plugged into the USB port through the Imagemate, you have problems. Could you try booting with just the Imagemate plugged in, but without any SD card installed?
  • SanDisk Master
  • 13,433 Answers
Try pluging it to another usb port, check device manager for error messages.
Right click on computer -> select manage -> on left side select device manager
Note anything with a yellow ! mark.
  • 1 more comment
  • Ekse May 28, 2008
    can you try the memory sticks on another pc do they work there?
  • Ekse May 28, 2008
    Are you intrested in remote assistance? I could take a look around.
  • Ekse May 31, 2008
    reinstall windows
REMOVER SD CARD
There isn't a memory card in the Cruzer. It contains a memory chip similar to what's inside a SD card. Even if you managed to extract the chip without damaging it, you'd need a different controller.
May 13, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Why won't my sandisk imagemate 5 in 1 reader recognize my 4GB sandisk SDHC card? Is my computer at fault? The camera is a Canon Powershot SD1200IS ELPH 10.0. Thanks. jhooten55@hotmail.com ...
The ImageMate 5-in-1 is compatible with SD, MMC, MS, MSPro, and xD cards. It is NOT compatible with SDHC cards.
While SDHC cards will fit into SD slots, they will not work in SD devices.
Aug 12, 2010 | Cameras
Blank screen on Thinkpad Lenovo T61, when I connect a monitor and reboot it shows scramble.. help
Your video card adapter might be damage. Or you have installed a wrong driver for your laptop.
Another cause of the problem is your RAM or memory might be damage. I suggest you buy a new memory to test it.
Thanks. Cheers!
Apr 21, 2010 | Lenovo ThinkPad T61 Notebook
SanDisk ImageMate 12in1 cannot read SCHC 4GB or higher cards
Correct!!!! This card reader cannot address cards that are higher then 3gig and cannot read sdhc cards. Most older readers will not be able to read the HC type card, and by older I mean if its 6 months old or more. To read these cards you need to purchase a new card reader. I know, My camera uses 4gig cards and I was unable to access the pics until I bought a new reader..
Dec 02, 2009 | Computers & Internet
Lenovo t61 laptop has no tcpip communication ran the "system health" test in Lenovo PC doctor 5 for windows. os XP pro service pack 2 ethernet card has both lights operating showing conection to network...
A couple of things need to be done.
Install SP3 this is the latest service pack for XP.
Install the TCP/IP (Internet protocol)
Open Control Panel - Network Connections - right click on Local Area Connection - click on the box for Internet Protocol (TCP/IP) and the click on Install.
Then reboot the computer.
You network should now work.
Nov 29, 2009 | IBM Lenovo ThinkPad T61 Notebook
Lenovo T61 Wireless not connected
To turn on the wifi card. Make sure that the driver is install the press FN + F5.
Thanks for using Fixya.
Oct 14, 2009 | Lenovo ThinkPad T61 Notebook
Camera reads, computer doesn't
That is odd. Try the recovery software that comes with the sandisk cards and see if you are able to get them after that.
Do you format your cards each time in the camera before shooting?
Jul 10, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Regarding Memory Parity check
this error is usually associated with bad memory cards......how much amount of memory are you using.....try reseating the memory cards(ram)....if you still get the error msg....try starting the system with jst 1 memory (if thr are 2 memory cards installd) & thn swap it with the other one......
Jul 18, 2008 | Lenovo ThinkPad T61 Notebook
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
275 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
