Question about Dryers
Seems to have heating element out. Clothes take two times as long to dry.
  • 4,340 Answers
Reset your breaker, that means FULLY OFF and turn on again.
Posted on Oct 04, 2010
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Needs two cycles to dry clothes!
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 19, 2012 | Kenmore Dryers
The heating element in my Kenmore dryer, model number 110.63032101, does not fully heat up sometimes. With the setting on cotton/high the element will sometimes be fully illuminated and sometimes only...
no,that's how they run,if your clothes are drying and the dryer is cycling on and off,leave it alone,if the clothes are taking a long time to dry clean out the duct that the lint filter slides into and blow out the vent line with a leaf blower if it's a long run
Oct 12, 2010 | Kenmore Dryers
My LG dryer seems like it is not drying clothes as well. In what used to be a standard amount of drying time, the clothes are still damp. Could the heating element be going out.
I would check your venting to make sure its not clogged. This will cause longer dry times because the dryer cant efficiently remove moisture. Just go outside and feel the air coming out it should be fairly strong, if not the replace or clean your vent line. Good Luck
Mar 13, 2010 | LG Dryers
My whirlpool wed5600sq0 I bought in 2007 never dried my clothes. There seems to be two heating elements in the rear drum. The larger one doesn't seem to heat up. Is this the problem? Is this a heating...
i think you will find that the heaters are in the front of the drum not the back,,,are the inlet and outlet pipes clear of dust and fluff some times its the heat sencors that have packed up on you it wont heat at all then,if any of the elements have falied it will still heat up a little but will take years to dry a full load
Oct 24, 2009 | Dryers
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
Not drying properly, no heat
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 06, 2009 | Dryers
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 03, 2009 | Kenmore Dryers
Leb6200 wont completely dry clothes first time.
the problem is most likely an airflow problem. if you have a flexible duct connected to the back of the machine then replace it with a smooth rigid (not pvc) metal duct. clean inside the wall or wherever the air goes to get outside (must be smooth metal at least 4" in diameter) in the wall, without too many bends. the electrical arc you spoke of would not have an effect on the heating element unless the machine is not heating at all.
Jul 04, 2008 | Whirlpool LEB6200 Electric Dryer
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
Dryers Logo
Top Dryers Experts
