I woukd like to have my heat electric, right now its gas and the AC is electric. I have added heat strips to an AC unit before but am not sure if i can with this one. They both one on one thermastat. Am i going to have to rewire everything or will it be as simple as putting heat strips in and turning on the heat?
    Problem Solver:
  • 9 Answers
Depending on the unit it might be possible but the 1st thing you have to do is change the wire to your unit probably to # 6 depending on the KVA rating of the heat strips. Your unit because it's gas it is wired only for 20 or 30 amps & most electric strips are 60 amps.
Posted on Oct 04, 2010
How do I reset the temp my heat pump switches from electric to gas. It runs much more economically on electri than on propane. The thermostat is a Honeywell th8000. Code 350 setting I believe. Thanks
Heatpumps are more complex than an AC unit. Yes, there is a difference between a heatpump and an air conditioner. Where the real difference lies is out side in the condenser unit. There's a defrost board out in the unit, and depending on the brand and model, one of the wires will need to be changed so that the gas furnace will not come on. The problem with this, heatpumps use the heat that is available from the outdoors and transfers it to indoor. When the temps outside drop below 50 degrees, there's not enough latent heat to transfer, thus calling the propane furnace to operate. Without the addition of the furnace, you will not be able to heat the area properly. The only way to remedy this, is to remove the propane furnace and replace it with an electric airhandler with a heat strip for "emergency heat". The emergency heat term is used when the temps drop below the temps I mentioned above and calls for the heat strips to come on.
Feb 03, 2017 | Honeywell Heating & Cooling
New heat strip does not come on with themo in heat position.
you cant use that thermostat for a heat strip,your thermostat only gives 9 volts to tell the heat pump to come on,a heat strip needs 220 volts to run,DO NOT PLAY WITH ELECTRIC HEATERS!!you do not know what you are doing and can burn your house down or hurt someone!!
May 22, 2015 | Heating & Cooling
Put on a new thermostat.......added a 5 wire to the system and does not work now
dont understand what you are trying to say. What is name and model of unit. what is name and model of the thermostat. do you have straight ac with gas heat, straight ac with electric heat, heat pump, heat pump with back up heat and what kind, electric or gas?
Jul 07, 2011 | Heating & Cooling
Working on a coleman 3ton split unit in a mobile home, when thermostat calls for heat, the heat strips come on and blower comes on. heat strips go off before the thermostat is satisfied and the blower...
Probably a bad limit switch on the strips or the heat sequencer/relay is falling out after continued amp draw. I would lean toward the heat relay/sequencer. Havent heard of any problems with coleman limit switches. These units were prone to get water inthe electrical compartments due to the evap coil being right above it. Check to see where the power break is starting at the strips and working backwards throught the circuit. That will tell you for sure. Make sure you have 24v going to the heat sequencer too.
Jan 19, 2011 | Coleman Heating & Cooling
I have a heil furnace ac is working heat wont come on?
Check the white wire is making contact well in the t-stat.
Is it gas heat or electric/heatpump
If gas then check your flame ignition system to determine if it is lighting a pilot or has a hot surface type glow element. If it does not sense the flame it will refuse to run gas for heat and or check that the electric enducer fan is comeing on before the pilot even attempts to light. It must run to prove a draft induction exist for the furnace baffles before it will attempt to start heat.
If it is a heat pump then it should fail to heat side on the reversing valve and not really need to be checked since your AC works. The call for AC has reversed the valve to even get cooling. So it is going to be heat strips failing or sequensers failing maybe even low refrigerant on a heat pump system. I know this is all a bunch to digest remember it is usually electrical and just a loose wire! So start from there and T-stats do go bad just because they can!
Oct 08, 2010 | Heating & Cooling
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
I have a Rheem Gas/Electric AC unit that provides both Air and Heat. Yesterday the heat stopped working... it blows out cold air. We've had some cold temperatures lately (low 20's) but this isn't unusual...
Heat pumps provide good heat until the tempurature drops below 35-40 degrees. After that there isn't much heat to extract from the outside air and then either the gas furnace kicks in or the electric heat strip does the job of heating the air. if you have heat strips, I would check your breakers in your panel and sometimes there are a couple of breakers right on the air handler or furnace. The ones that will be for your heat strip are 220v and will be twice as wide as your normal 110v breakers . Please don't trust a visual inspection as they can look like they are in the "on" position but are indeed tripped. Turn them all they way off and then back on. If the beakers check out you may have an open cicuit in the heat strips themselves and you will need to have a qualified HVAC tech look at your furnace to repair it.
If your furnace is a "duel fuel" and uses natural or LP gas for back up heat then your ten year old rheem probably needs a good maintenance by a qualified service tech. There is a flame sensor to clean, ignitor to check (replaces the old school pilots), burners to clean flue connections to check and much more. ALL manufacturers of any heating apliance recommend yearly maintenance. Most companies offer something for around 100 bucks. I hope this helps.
Rocco
Dec 12, 2009 | Heating & Cooling
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Heat doesn't work on ac unit
u have to be more specific. is it gas or electric. If electric check breaker first. Gas check thermocouple
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
