Question about Razor E300 Scooter
How do you change the tube on the E300's rear tire?
    Problem Solver:
  • 18 Answers
Just buy a new rear wheel. The wheel is not meant to come apart without breaking a couple fingers in return. Besides the new tube is about 15 dollars add the shipping and for another 20 dollars you can get it brand new complete, wheel, tube, rim, axle. I'm not saying it can't be done but why put yourself through this.
Posted on Nov 09, 2010
How do I change the inner tube on my rear tire
This is no easy task!
You will need to remove the rear wheel to access the wheel, tire, and inner tube
Unless you have a single speed rear axle, you will be needing to disconnect the multi-speed gearing, which you may not really enjoy.
God bless your efforts.
Apr 19, 2016 | Schwinn 24in Riverside Girls Cruiser Bike...
How to change rear tire ?
Remove rear wheel with either a 15 mm or a 17 mm wrench. Take the tire off the wheel. If you are replacing a tire, reverse procedure. If you have a flat, replace inner tube, then reverse procedure
Aug 14, 2014 | Huffy Cranbrook 26" Mens Cruiser Bike
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
How to change back innertube on 26" mongoose estes bike
First turn the adjuster on the rear brake handle all the way in and make sure the slots on the adjuster and set nut are lined up, pull the brake cable out and leave it attached to the lever to open the rear brake pads, loosen the bolts on the tire and pull the derailer up to remove the tire, remove the dustcap from tube and using a flat tool (Wal-Mart has tire tools for $1) take one side of the tire bead out of the rim, pull the old tube out, place the stem of the new tube in the hole and put the cap on, tuck the new tube in the tire trying to keep it flat as possible, push the bead of the tire back into the rim. before inflating the tire, put it back on the frame while pulling the derailer up to get the chain back on the cogs( they will adjust later) tighten the bolts and inflate the tire to desired pressure (between 35-60 psi)
Jul 05, 2014 | Mongoose Cycling
How to put air in tire of e300 razor
  1. rotate the rear wheel until the hole in the sprocket lines up with the tyre valve.
  2. insert the tyre valve extension through the hole and attach it to the tyre valve
  3. inflate the tyre to the correct pressure (usually 45psi)
  4. remove valve extension and put in a safe place for next time.
Inflating the rear tyre is detailed in the owners manual, which you can download from the Razor web site.
http://www.razor.com/au/products/electric-scooters/e300/
Jun 25, 2014 | Razor E300 Scooter
When i push the thumb control down the motor comes on and the chain turns but the rear tire does not what is causing this? thank you
sounds like you need a new rear wheel as the wheel locking mech has been stripped or damaged where the cog is at. Can you move the wheel forward and backward with out the chain moving? If so that is your problem.
Sep 28, 2010 | Razor E300 Scooter
If the sprocket and chain turn on the rear wheel, it sounds like the freewheel on the rear tire is faulty.
Fuel pump in 2002 Lexus E300?
remove rear passenger seat, and lock for a metal cap with wire in center , open and below is fuel pump
Jun 08, 2009 | 2002 Lexus ES 300
Razor E300 Scooter Logo
1,112 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
