Question about GE 169137 Classic 4-Slice Toaster
Model 169096 4 slice toaster--The right side will not stay down. Will toast if i hold the lever down. Have cleaned crumbs out nd still not working
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
SOURCE: when i push the lever down to make toast, it does not stay
no solution, problem, my lever (sometimes) will stay down, sometimes not, but it makes a loud "ractething" noise many times when the lever is pushed down>
best, randy
Posted on Dec 12, 2007
SOURCE: Digital Display no longer showing, lever won't stay down
YOU HAVE A DEFECTIVE DIODE THAT LITES THE LCD. A .99 CENT PART. SELLER SHOULD REPLACE THE TOASTER WITH OUT QUESTION.
Posted on Sep 30, 2008
MNfisherman
  • 11896 Answers
SOURCE: The handles would not stay down
turn temp knob up more and they should work.
Posted on Jul 10, 2009
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
We have the four slice toaster. The arm on the left will no longer stay down. The side still toasts, but the arm will not lock in the down position.
try removing the lower claening plate and remove the bread crumbs and see if that makes it work again. Many people don't know there is a cleaning try on the toaster.
Mar 21, 2010 | VillaWare 5850 Uno Classic 4-Slice Toaster
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
6331 will not stay down
I have the 4-slice oster, but I bet the control mechanism is the same. When you take it apart you will see a small steel bar held by two plastic fingers. When you push the lever down the steel bar moves down and contacts a small square electromagnet. The electromagnet holds the lever down during toasting and releases the lever when done. On mine there was a compressed layer of bread crumbs covering the electromagnet. Cleaned it off and now it works again.
To take the toaster apart, pull the down lever straight out and then unfasten the screws on the bottom base (5 on mine) and pull the top off carefully. There are wires connecting the control face to the base, but they have enough slack to let you separate the top/bottom and access the mechanism.
Nov 24, 2009 | Oster 6307 / 6309 2-Slice Toaster
Jul 10, 2009 | GE 169137 Classic 4-Slice Toaster
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Dualit 20247 2-slice toaster
Very often it's simply crumbs in the wrong place.
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This is operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Jun 25, 2008 | Dualit 20247 2-Slice Toaster
Lever on taoster will not stay down
Black & Decker T4050 OptiToast 4-Slice and it will not stay down and heat either. However you can hold it down and then it will heat. I apparently has an electromagnet that is supposed to hold it down and it's not working. Any Suggestions?
Oct 30, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Lever won't stay down Breville CT20
hi sounds like the problem is the holding down mechanizem clean the toaster well find that spring which caches the lever down you can find it on the external lever side pretty small and simple thing when you push down the external lever the spring kick a little lever which holds the slide in place for heatup only when you will hear a "click" then you'll know its in place and then the electric cicuit will be close and engage the coils to heatup good luck
Mar 30, 2006 | Breville CT20 Retro Classic 2-Slice...
GE 169137 Classic 4-Slice Toaster Logo
90 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
