Red hases around faces hands ect - Televison & Video
    Novelist:
    Champion:
  • 216 Answers
Greetings dagwood3117,
It is possible you need to perform convergence on your projection television. This can be found in the setup menu. Basically what happens is the different projection bulbs or rods come out of adjustment and need to be tuned. It is something you should be able to perform yourself.
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on May 27, 2008
DO NOT HAVE HAND BOOK NEED TO KNOW OPERATION OF EACH FUSE FOR LIGHTS WINDOWS ECT.
GET A GOOD FUSE TESTER, TEST EVERY FUSE . FUSE BOX UNDER THE HOOD INSIDE THE CAR WITH IGNITION SWITCH ON. THE FUSES CAN BE TESTED IN THE BOX THERE ARE TEST POINTS FACING OUT. GOOD LUCK, DR. VOLT
Jan 21, 2011 | Lancia Beta Cars & Trucks
I have a mercedes c180 2003 model i have malfunctions on the right hand signal lights front and back reversing light brake light all on the right hand side changed the bulbs its not them checked the fuses...
Its possible that its the cluster its self if possible depending on harness ect can you swop the clusters around left to right ect just to see if the lights work with the cluster swoped round the old ones had just 1 plastic tab thing that keeped them in the light part and the cluster bulbs ect where a seperat part if it was fuses ect all the lights would go off not just one side check earths ect they may be behind the cladding bits at either side of the boot make sure there ok hope this helps ivan
Nov 01, 2017 | 2003 Mercedes-Benz C-Class
Where is the coolant temperature sensor on a 1999 honda crv?
Good Day
the ECT sensor is located on the cyl head near the coolant outlet, so if you are looking at the eng from the front of the car stand in the middle you will see the rad put your left hand on the rad then with your hand on the rad(left side) move your hand towards the back of the eng approx 6" the ECT will be around that area:
if you are replacing the ECT after putting the new ECT in warm the eng until the coolant fan turns on and off twice.
I hope this helps
Cheers
Jul 09, 2009 | 1999 Honda CR-V
I lost sound after fomating my laptop-hasee F420s
GO TO THE MANUFACTURER SITE AND FOLLOW THE INSTRUCTIONS TO DOWNLOAD THERE ..... BE AWARE THAT THE SOUND CARD MAY BE DIFFERENT THEN THE BRAND NAME OF YOUR SYSTEM IE: NVIDIA ECT.
GOOD LUCK
Jul 09, 2009 | Computers & Internet
Vaccuum will not pick up very much off of the floor
You have a clog in the hose or port going from the brush's to the dirt container. You can blow these out with a compressor. Note: You must seal the end (can use your hand wrapped around it) that you put the compressor hase in. You can also use a more powerfull vacuum that has a exaust on it to do the job.
Apr 15, 2009 | Vacuums
I went to change the solenoid on my 88 lincoln and I turned a bolt and the whole this disinegrated, now I don't know if all the yellow wires go on the one post of the new one and the red on the other or if...
the wire going to the starter follow it down towards passenger fender down this cable depending on the solenoid is either bottom terminal or if solenoid bolts different it is on the right hand side if you are facing the solenoidThe skinney red wire goes to the S marked on the solenoid FOLLOW WIRE COMING FROM BATTERY THIS GOES ON TOP ECT. AS BEFORE ALL OTHER WIRES THAT DO NOT GO TO THE STARTER WILL GO WERE THE BATTERY CABLE GOES .
Mar 10, 2009 | 1988 Lincoln Town Car
Light blue shade of hase in middle of the screen with
Light Engine FOR SURE Just did one last month retail on part $2,500.00 Call UED I got mine for around $900.00 1-800-648-6657 ask if they have any rebuilt ones cheaper.It was for a 55 inch prices very . I checked on a 42 and with core exchange 400.00
Jan 01, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Whirlpool dryer
if u can turn the drum by hand than more than likly the belt is bad or there may be somthing stuck in the edge of the drum ie kids toys ect ect or the motor for the drum has failed unplug the unit if you can take off the rear cover you should be able to see the belt that goes around the drum or you should see the motor for the drum check to see if the belt for the drum in inplace if not get a new belt and if the motor can turn by hand buit it wont turn the drum check to see idf there is a red button to reset the motor if not than the motor is probably bad check to see if you still have a warranty good luck keep me posted best regards mike
Aug 09, 2008 | Whirlpool LER5636P Electric Dryer
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
