Question about Leviton Decora Light Dimmer Switch
Need to hook this up to a lutron eco-t528-277-2 ballast which only has a hot,dimmed hot and neutral
If I understand correctly, you have Leviton florescent dimmer
And you want to connect dimmer to Lutron ECO-series ballast
This is the ballast with 3 wires: Hot dimmed, Neutral and Hot
Is this your dimmer???? Has Black, White, Red, Yellow-red, & Orange
Here's how to do it:
Dimmer yellow-red is not used except for 3-way switch >> cap it off with wire nut
Dimmer orange wire connects to ballast Dimmed Hot
Dimmer red wire connects to ballast Hot
Dimmer white wire connects to ballast Neutral
Those are your wires going to ballast. As you can see, you need 3 wires going to florescent fixture
Next, let's focus on Dimmer:
Dimmer green wire goes to bare ground wire
Dimmer black wire connects to Hot from breaker box (we'll test for that next)
Finally the Dimmer white wire connects to ballast Neutral as discussed above BUT is also has to connect to Neutral from breaker box
This means the Dimmer white wire is connected to 2 wires >> one wire goes to florescent fixture and the other wire comes from breaker box
So which wires come from breaker box??
It should be a black and white wire.
Let's test to find Hot and Neutral that come from breaker box.
Mark your wires.
Disconnect all the wires and separate from each other
Turn on power
Use ordinary tester
Tape tester leads to wood sticks so hands stay away from electricity
Power is on
Test each wire to bare copper wire
When tester lights up, that is Hot from breaker box ... this wire connects to Dimmer black wire
Now, test the hot wire to each of the other wires
When tester lights up, that is Neutral wire ... this wire connects to Dimmer white wire, and also connects to Ballast neutral.
Connect one wire at a time, and it will work.
Posted on Oct 06, 2010
Switch and dimmer work opposite each other
Refer this issue directly to Lutron. They could have an ineresting explanation!
Jan 27, 2014 | Lutron Toggler Single Pole 600 Watt Preset...
New dimmer switch not working
Hi -
The Lutron D600P is a preset single pole dimmer. Wiring is pretty straight forward as show in this diagram. Recheck wiring and if OK, continue below.
If power is present on both wires (black / red wires), power is being passed through the switch to the lamp and the light should be on. If not, try replacing the lamp.
Minimum recommended connected load is 40 watts. This switch is ONLY for use with filament type lamps - such as traditional tungsten, halogen, etc. It is NOT to control speed of Fan Motors, nor dimming of CFL (compact fluorescent lamps) energy saving types or other ballast operated lamps such as High (or Low) Pressure Sodium, Metal Halide, Fluorescent, etc. as this would create a high heat condition and could cause a fire.
If you're still having trouble, you can contact Lutron Technical Support Center 1.800.523.9466 24 hrs / 7 days www.lutron.com
I hope this helps & good luck!
Sep 02, 2012 | Lutron #D-600PH-DK 600W SP Push Rotating...
My 4ft fluorescent fixture has whiye and black wires that have been connected, hot and nuetral but it also has a red (brown) wire ? where does this go.
They make dimmable ballasts.
The Lutron dimming ballast shows an orange wire, not a brown >> but other manufacturers might call for different color.
I am guessing here, but ballast should work with Black Hot and White Neutral
I want you to answer back and say if the ballast works with just white and black, Thank you.
Here is a 3-way dimmer to control florescent ballast
Oct 18, 2010 | Lithonia Lighting Lithonia Ps300...
After instalation of 600w lutron eco-dim dimmer (single pole) with halogen dimmerable light bulbs ,there is a buzzing noise coming from the ligts.The volume of the noise changes with the position of the...
This, unfortuantely, is one of the usual challenges associated with dimming. The buzzing usually gets worse at around the 1/2 light level point. I don't think the issue has to do with whether the lamp is halogen, but rather how the lamp is physically constructed - and that differs from manufacturer to manufacturer. Long story short, I would take note of the lamps you purchased, and when replaced, I would opt for a different manufacturer.
Sep 18, 2010 | Lutron 600W ECO DIMMER
We installed the new fourescent bulbs in our can lighting...some work great..other flicker for no apparent reason...does it have to do with the settings?
You can not dim compact fluorescent lamps. The ballast for the fluorescent is built into the bottom of the lamp. IF the manufacture says that it is dimmable, then you would need a special interface (Lutorn FDBI) to make it work properly. It may work for a short while with out it, but will burn out the ballast or dimmer.
Oct 24, 2009 | Lutron S-600H-WH Slide Dimmer
Lutron Dimmer Not Dimming But On/Off Works
What is the dimmer rated for? Your load on the track appears to be 200 watts. A standard dimmer will burn out, you need to look on the dimmer to see what it is rated for. Did it run hot with the dimmer before you had this problem? They make dimmers for higher wattage that will do the job for you.
Feb 05, 2009 | Lutron ELECTRONICS S-1000H-LA SKYLARK...
Fluorescent dimmir
The dimmer you purchase needs to be compatable with the ballasts of the C.F. light. A compact flourescent potlight has a ballast, if your replacing incandescent bulbs with compact flourecent lamps
you still need a flourescent dimmer. Remember a ballast is like a transformer! If you compact flourecent fixture has a ballast by Lutron. then you need a lutron dimmer as there ballasts are not officially compatable with other dimmers, allthough I've seen them work. My advise is buy Pass & Seymour (Legrand) or Leviton.
Jan 21, 2009 | Pass & Seymour / Legrand DFB600-M 600VA...
Have a Lutron Skylark SF-10P need to wire to existing 3 wires
You have to have a special ballast on the light to dim fluorescent light fixtures. You also have to have a special dimmer.
Nov 28, 2008 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
How many dimmers types?
Certain dimmers can control standard incandescent lamps that use 120 volts while other dimmers can control low voltage xenon or halogen light sources that use 12 or 24 volts.
Aug 27, 2008 | Lutron Electronic Low-Voltage...
Leviton  Decora Light Dimmer Switch Logo
664 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
