Question about Kenmore Dryers
Dryer basket stopped turning, does heat up - Kenmore Dryers
    Sergeant:
    Champion:
  • 351 Answers
Belt may have broke or come off
Posted on Oct 04, 2010
Whirlpool dryer mod WED8300SWO stops before clothes are dry
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 13, 2015 | Whirlpool Dryers
Dryer stops working and all censor lights have lit up./....
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Feb 24, 2015 | Dryers
My roper dryer starts runs few min. Then stops
Feb 17, 2015 | Roper Dryers
DRYER WILL NOT TURN ON AT ALL
Hi.
If the dryer does not start and does not heat check thermal fuse and door latch. Both parts can be tested reading impedance with a multimeter.
If the dryer starts and heats up but the basket does not turn, check the motor and the belt. In that case you probably have a broken belt.
Regards.
Ginko
Dec 15, 2011 | Maytag PYE2300AY Electric Dryer
On my washer/dryer stacked combo, the dryer has a new rubbing sound when the inside basket turns. It may feel as if the basket has fallen a little but I never checked it before so it may be sitting...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 21, 2010 | Frigidaire GLGT1031C Dryer
Is not getting hot.have cleaned the lint basket and pulled the basket holder and cleaned behind it. still not getting hot. could it be the heating element?
Deffinitely the next thing I would test. If it is tumbling and the timer is working, save having a wiring issue, which is highly unlikely, it probably does need a heating element.
Dec 07, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer is slow to start. Motor makes a straining noise when starting but basket seems reasonably easy to turn.
take the belt off the motor pulley and make sure the motor bearings are free, heat will kill the bearings on the motor
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Ultimate care heavy duty dryer is not heating
SOUNDS LIKE YOVE GOT A CLO OF LENT IN THE LINT BASKET CLEAN AND LET ME KNOW HOW IT TURNS OUT
May 03, 2009 | Dryers
Dryers Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
