Question about Maytag Atlantis MDG7400AW Gas Dryer
Dryer does not heat up. igniter comes on, but gas does not flow to be lit. checked for a clogged gas line, but that is o.k.
    Sergeant:
    Champion:
  • 351 Answers
Even though the ignitor comes no may still be bad i would try that first
Posted on Oct 04, 2010
Our dryer is gas and we are having issue with it. It runs, spins and such but we aren't getting the heat to dry the clothes. We are not sure if there is a reset switch or something else we are...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 28, 2011 | Dryers
Dryer suddenly stopped heating
Most of the time when the dryer stops heating is fron a clogged up venting tubes that restrict the flow of the exhaust. The moister sensor detects that and keeps the heat in check.
I would clean the entire exhaust tubing thoroughly and recheck the operations of the heat flow. If this does not get this to work listen for the click of the electronic starter to ignited the burner if gas powered
Jun 18, 2010 | Dryers
DPXH46 GE gas dryer won't stay lit. Already replaced igniter and selenoid coils. What now?
sounds like the vent line is clogged with lint clean out the dryer and take the vent line off the back and blow out the line with a leaf blower,check outside and make sure the air is blowing open the flapper
Oct 30, 2009 | GE DCVH515GF Gas Dryer
GE gas dryer flame won't stay lit. I have a GE gas dryer that is about 8 or 9 years old. The dryer will go through a whole cycle, but the clothes will not come dry. I checked the vents for a clog and took...
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Aug 24, 2009 | Dryers
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
Flame goes out after 5 seconds
the thermocupple is a small tube that when heated shrinks to let gas flow if it is no good gas will not flow change the thermocupple thank you for useing fixya please rate me
Feb 24, 2009 | Dryers
Maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Speed Queen dryer does not heat...
you have weak gas valkve coils and they will work when cold but after a few cycles they become electrically open and will not allow the gas to flow.
just replace both gas valve coils and that will fix your problem.
Dec 29, 2008 | Speed Queen AES68AWF Gas Dryers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Maytag Atlantis MDG7400AW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
