Question about Jet 7 Portable Power Chair
I have a jet 2 how do you replace the battery
  • 692 Answers
Cowboyboots First unplug the joystick cable's 9 pin connector from the rear of the chair. If your chair has a center post that supports the seat-- on the right side under the seat is a lever push it forward and twist and pull up on the seat at the same time. If the seat has not been removed in a long time it can be very stubborn and you will need help to get it off the post. Once you have removed the seat and set it aside. Align the freewheel levers with the slots in the shroud and pull the shroud up and off the frame. It has velcro tabs, so you will need to rock it back and forth until you hear the velcro release. You might have to give it a good yank but be careful not to break the plastic. Once the shroud is off you will see both batteries and associated cables. Unplug the cables, lift the batteries out of the frame and remove the cables and reattach to your new batteries keeping the same polarity red on red ,black on black. Now that you have the cover off its a good time to give the inside of the chair a good cleaning using a air hose or small vaccuum to get to get the dirt and crud out. reinstall your batteries like you removed them wipe down the shroud. Before putting the seat back in the post grease it with any good grease or even vaseline to make the next time alot easier. reinsert the seat post into the chair reconnect your joystick cable and you should be good to go. Hope this helps you
Posted on Oct 04, 2010
How to install a new battery
Viola, Take it into the source and they may change battery for you just for you purchasing a new battery from them. I will post links to help on how to change rechargeable battery,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RCA S2001 Battery S2002 Jet 2 GB Digital Player
RCA S2001 Manuals Support and Troubleshooting MP3 Players
RCA Support
How to replace battery MP3 Player Creative Zen Plus total reset
Mar 03, 2016 | Audiovox Rca S2001 Jet Series Sports Mp3...
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
WHERE CAN I GET A REPLACEMENT BATTERY # BATLIQ1001 I LIVE IN CHINO HILLS,CA.
just find a battery distributor in your area and ask if they have a U1 AGM sealed cell battery you will need 2 batteries for your chair Hope this helps
Jun 20, 2011 | Jet 3 Ultra Power Chair
Unit charges shows full and by mid day in a nursing home battery lights show only 2 red lights. do i need to replace batteries. the chair is a jet3 it was bought in 2003 and not used for about 2...
You definitely need new batteries. There are 2 size U-1 batteries in the chair that will last between 1.5 and 2 years. Get the deep cycle sealed gel lead acid batteries, preferably AGM. Hope this helps.
Feb 15, 2011 | Jet 3 Ultra Power Chair
Had not used the jet for several years and batteries would not charge. replaced batteries and new batteries will not charge, meter will not work or move when jet is plugged in. jet worked with new...
You'll have to get to the battery terminals while they're charging, and then you can measure the charger voltage, if any (around 12 v).
It sounds like your charger is bad, and you can order one from this site:
http://www.monsterscooterparts.com/jet3ultra.html
Good luck, and hope this helps you.
Nov 07, 2010 | Jet 3 Ultra Power Chair
Replacement batterys for jet 7 wheel chair?
Yep u need 2 U1 batteries. Check in your area for a battery warehouse type store or an Interstate battery store they can get the U1 s you need and might have them in stock. Try to avoid going to a provider as they will charge you alot more than the battery stores Hope this helps you
Sep 10, 2010 | Jet 7 Portable Power Chair
Samsung S8000 Jet not turning on.
hi, try these for troubleshooting your jet.
1. borrow the same type of battery and the same type of charger.
2. remove your battery and insert the borrowed one(which is fully charged of course) to your phone.
3. switch it on and check if it will give you the same issue. if not, then you might need to replace your battery.
>>troubleshooting your charger
1. with your jet's battery ( which you own), plug the borrowed charger and observe. if it doesn't give you the same issue, i suggest, if it's under warranty, you would want to go to your nearest service center and have them check your phone., they may or may not charge you with the service but it will help you to find what is really the problem.
for added info.
switching of phone on and off, is the result of.
1. there is no enough power to supply your phone
2. problems with the firmwares, not updated completely
3. charger are not giving the right voltage to charge the battery (this is sometimes you see that it is fully charged but in the actual test it is not)..
i would suggest to make a comments once you have done the troubleshooting.
regards..
Mar 10, 2010 | Samsung Jet S8000 Cell Phone
The battery on my jet 3 will not charge
you need to replace both batteries, their called U1 batteries (35 AMP-Hour)
Jun 08, 2009 | Pride Mobility Products New Pride Mobility...
Jet 7 Portable Power Chair  Logo
251 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
