Question about Philips Senseo HD-7810 Coffee Maker
I have the Senseo Latte 7850 machine. Seems to work fine and does all the things it should but the resulting drink is not very hot at all. Same story with hot chocolate drinks. Is there way to adjust the temperature of the water ?
  • 24 Answers
If you don't have the machine all that long I'd make use of the warranty. Opening it yourself will void the warranty . .
Some makes and models do have controls on the PCB which allow for water temperature adjustment and cup filling level, but you'd need to open the machine to get to them.
Posted on Oct 28, 2010
Senseo 7860 leaks
maybe you can see more at the Philips website
7860 leaks... where????? SENSEO Coffee pod system HD7850 60 Latte Select
Jan 19, 2014 | Philips Senseo HD-7810 Coffee Maker
Drink-o-matic seems to run fine but doesn't get cold
Power supply is getting weak, and or the room is way too hot.
Nov 10, 2012 | Sharper Image Drink-O-Matic
No water comes out of the tassimo T40 when making a drink.
I found that the cleaning disk puts through the correct amount of water but coffee disks don't. Suspect then that the problem is related to the pressure or flow from the system when disks are in , or the cutter part. I have now bought a new machine. I can swap this part across and check to see if this issue with non delivery of correct quantity of water its related to the suggested worn cutter.
Jul 23, 2012 | Braun Tassimo Hot Beverage System - T-DISC...
Delonghi Lattissima EN 660CW milk frother not frothing
I don't know why my answer posted in the comments section, so here it is in the proper area.
I had the same problem and was ready to send it in for repairs, but I talked to a great guy at Nespresso who helped me fix it myself. The problem was when I pushed the latte button, it would only froth milk for a second or two and then the espresso would start pouring. It basically refused to make a latte. Here's the things he had me do:
1) Descale immediately. I have an older machine, and descaling once a year does NOT cut it. He told me descaling every 5 months at the bare minimum, if your machine is not having any problems at all. Descaling is usually the main problem for lack of froth. I descaled and it seemed like the machine was working better almost immediately. I also ran 4 - 5 tanks of water through the hot water spout and the main espresso part (but mostly this is because it seems to take this much flushing to get the smell of the descaling solution out).
2) Reset your machine to factory settings. I have a classic Lattissima, so this is how you do it on that machine. Turn the machine on and wait until the drink buttons are steady (espresso and hot water buttons are no longer blinking to warm up). Then press and HOLD the power button until the espresso and hot water buttons BLINK THREE TIMES. Then they'll go back to steady again. You're now back to factory settings.
I did notice that I started having the trouble after moving the machine, so I'm not sure which of the above solved the problem. The main thing is it worked and I'm back to yummy lattes!
Jan 09, 2012 | DeLonghi Nespresso EN660 Espresso Machine
Where can i get instructions for this machine and does it do hot chocolate
With the separately available chocolate pad holder it will do a fine cup of hot chocolate.
Assuming you need the US version of the manual, you can find it at http://www.senseo.us/Pages/SearchResults.aspx?terms=manual&start=0&scope=www.senseo.us
Sep 03, 2010 | Philips Senseo HD-7810 Coffee Maker
My philips senseo new generation won't open I suspect a vacuum-problem but don't know how to solve this can you advise me?
Eureka! I have solved this problem.
Disconnect your Senseo from the power. Take it to the sink. Hold it upside down and put hot water in the coffee outled. In less than 30 seconds the senseo will open.
The problem with Senseo is that - especially with coffee holders for 2 cups and chocolate - after making the coffee, the pod holder and the pod cool down. This creates an underpressure, that prevents you opening the Senseo. Hot water will increase the pressure and then you can open the senseo very soon.
This solution was found in despair after struggling with all the complex tool involving (knives, pumps, etc.)
Let me know if it works for you
Hans Beers (hansbeers@zonnet.nl).
Mar 26, 2009 | Philips Coffee Makers & Espresso Machines
Cocoa latte hot drink maker
replacement parts for valve, lid, and bowl can be found here
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3169&secid=53&linkon=subsection&linkid=118
part no. description Price
U27-2 Lid, White. CA series
$3.50
U18-182 Blending Jar with Built-In Stir Paddle
$12.00
U17-104 Dispensing Valve, Beige. Interchangeable with all Cocoa Latte Models
$5.00
Jan 23, 2009 | Back to Basics CM300 Coffee Maker
Steamed milk
I've just taken delivery of an S9 and my lattes were lukewarm too. What you have to do is move the dial on the steamer to the 3 o clock position. See http://cdn2.libsyn.com/coffeegeek/jura_frothxpress.mov?nvb=20081110133816&nva=20081111133816&t=018ee7ad85c33f422c6a5 . Latte I just made was piping hot. If that doesn't fix it, try the Products settings. If still lukewarm I think you should contact your dealer, maybe you have a duff machine.
Oct 18, 2008 | Jura Capresso Impressa X90 Espresso...
Manual or instructions
http://www.focuselectrics.com/supportdata/L5750_CocoaLatte_CM300_ALL.pdf
Downloads complete manual as PDF. I lost mine too.
Sep 21, 2008 | Back to Basics CM300 Coffee Maker
Aug 22, 2008 | Back to Basics CM300 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
354 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
Ross Keen
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
