Question about Dell Inspiron 2650 Notebook
Recharging failed I replaced my labtop battery cells but it is not charging, I checked for voltage, it is reaching to the battery, but the battery just will not charge. now I think the control sercuit inside the battery is to be plamed. is there any way to service this sercuit or find the schmatic diagram for it. Battery is for inspiron 2650 any help is appreciated. thanx
    Problem Solver:
  • 15 Answers
Get a similar battery and test u know battery is jsut a big capacitor so even though it reads well at times u discover its dead.
so replace a diff batery n see what happends
Posted on May 28, 2008
Can a dead battery be recharged and how
If you have a capable battery charger, then a dead battery can be recharged. I would suggest recharging the battery to the proper voltage and then letting it set for 24 hours. In 24 hours check the battery for the correct voltage. If it maintains the charge, then you should be okay to reinstall the battery. If it does not, then you may have a dead cell in the battery and it would need to be replaced. Video about How to Test Battery
Aug 28, 2014 | Exercise & Fitness
Shutter release disabled recharge battery
If you are using the same battery, it could be it has reached the end of life. The charger can indicate the battery is fully charged, because the voltage has reached a correct level, but still the battery can have one or more bad cells. So as soon as you start using the battery, it can lose enough energy to give this nasty message. If you put in another battery and still have the same message, there must be a serious problem in the camera.
To check your battery, just after the camera has given this message, with a multi meter. You will see the voltage has dropped at least 1,2 volt beneath the voltage printed on the battery. The typical 7 volt Nikon battery, will give 8 volt on the multi meter. But placed in the camera it will drop to 7 volt. If the multi meter reading is less then 7 volt it has at least one bad cell and should be replaced.
Dec 27, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Hi. I have new Samsung SGH-X495 and I have not used it for 3 years . I started to charge the battery for 7 hours but still charging. I just to find out either this is normal after 3 years charging or I...
Rechargeable batteries fail if stored for long periods in a flat state.
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 28, 2013 | Cell Phones
My Xperia X10i after it reach to 100% battery charge and unplug it. Its starting to re-start and re-start until it will not power on anymore?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 31, 2013 | Sony Ericsson XPERIA X10 Cell Phone
Why my coolpix s4300 will not charge
How old is the battery in the camera? Most rechargeable batteries will eventually lose their ability to charge. Usually one cell of the battery fails and the battery never reaches full charge. If the battery is more than a year old, replace it. The Coolpix S4300 uses the EN-EL19 and suggested retail price of $41.
If you have tried a new battery, I would suspect a problem with the charging port. That isn't something I recommend fixing yourself.
I hope this helps.
Jan 04, 2013 | Nikon 26304 Coolpix S4300
Won;t crank
Hi, if the car engine fails to crank, there is a fault in one of the components in the battery/ignition/starter circuit. Low battery (Check battery voltage, recharge if low, or jump start with another vehicle or battery charger). Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay). Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Replace ignition switch if defective).
May 26, 2011 | 1994 Dodge Stealth
My cell phone will not charge,,What can I do?
Ifthe phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.Check power adapter's DCplug that connects into the cell phone power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.
Apr 14, 2011 | AT&T Cell Phones
My phone is charging but it discharge in very less time automatically with using.
Check the voltage on the charger unit , if OK check the voltage on the terminals in the phone without the battery.
if the readings are good which is almost more than the battery voltage then the battery is worn out.
finally discharge off the battery and recharge, if not replace with original type..
Feb 15, 2011 | Cell Phones
Toughbook will not start, we have it plugged into the wall and when we switch it on the battery light turns red and nothing else happens? Thanks, Brad M.
> battery light turns RED
For Panasonic computers, that indicates that the battery is almost completely discharged (it's YELLOW while charging, and GREEN while fully-charged).
So, my guess is that your AC adapter has failed,
and that your battery needs recharging.
Or, the socket where the AC adapter connects into your computer is damaged, such that no power from the AC adapter is reaching the computer.
Take a "MultiMeter" and check the voltage & amperage output-level from your AC charger. If "zero", go onto eBay and search on the part-number, to find a compatible replacement part.
Oct 11, 2010 | Panasonic Toughbook 28 Notebook
Labtop battery goes dead very fast.
Depending on the age of the battery this may or may not be a problem. Most rechargeable batteries reach a point were they will no longer hold a charge. I've reached that point on my 7 year old HP laptop and will be getting a new vatterty any day now. I'm assuming your laptop functions if you use the power adapter and have it plugged in. If not your problem is probably not the battery but the laptops power management circuits. Replacing the battery is a pretty simple DIY job. All you'll need is a screw drive and some free time.
Jan 24, 2010 | Computers & Internet
Dell Inspiron 2650 Notebook Logo
71 people viewed this question
Alun Cox
