Question about Electronics - Others
Why should my 12v charger suddenly stop working
  • 283 Answers
Have you checked for a blown fuse?
Posted on Nov 03, 2010
Why did the cruise control suddenly stop working on my 2011 Dodge Charger?
When the clock spring breaks the cruse control and horn will not work and the air bag light stays on. Not this? check fuses
Sep 10, 2014 | 2011 Dodge Charger
My garmin zumo 550 will not chage from 12 volts either from car charger or motorcycle but it will charge with the 110v power plug
If the unit uses the same port for charging either 12v or 110v and it works with the 110v then I'd say look at the 12v charger unit itself. If you're using the same unit (12v) in the car and the bike, more than likely the fuse is blown in the 12v charger or is just went bad.
Oct 08, 2013 | GPS
Suddenly I can not charge my iPhone 3gs (iOS 4.2.1) with my 12V charger in the car. Any idea what is wrong ?
When pluged into the car liter outlet does the moniter light come on? 1 check the fuse by unsrewing the pin tip of the plug, look to see if the fuse is blown, you may need a OHM merter if you can't see if the wire is still in one piece. 2 check the cigar lighter in the vehical with another plug or lighter to see if it works if not then find whitch fuse is blown in the fuse box of the vehicle, and replace either or both.
Feb 10, 2011 | Apple Car Charger for iPhone 3G (12V~24V...
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Fan switch stopped working 1 mth after replacing the resistor
1) Check for +12v power from the fan select switch at the resistor pack - (If +12v is available there you may again have a faulty resistor pack).
2) Apply +12v directly to the fan motor to check that it runs ok.
Oct 06, 2009 | 2003 Hyundai Santa Fe
660 nuvi charges fine with AC charger, but not with 12v car charg
The real question is this:
1. When you plug the Nuvi onto the cradle, do you see a yellow lightning bolt appear over the battery icon at the main menu?
Compare it with the AC charger. If you don't see the lightning bolt, then you either have (2) problems:
1. There is a problem with the car charger not feeding power to the Nuvi.
2. There is a problem with the rear cradle socket on the Nuvi.
I have fixed both problems before. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 04, 2009 | Garmin Nuvi 660 GPS Receiver
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
