Question about GE Lands Phones
Intercom flashing My intercome light is blinking red and green. How can I stop that?
I didn't fix it myself. We had a phone technician come out to fix the line outside and that must have solved my problem. Thanks
Posted on May 28, 2008
I just bought a Wireless Intercom System. I hooked
frequency problem. check your partners/pair intercom system.
Oct 12, 2013 | Computers & Internet
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
The intercom light on my GE 2-9451 phone is flashing between green and red
This is what is in the user manual about the ligth means
Red Someone else is using the line.
Flashing red fast Incoming call.
Green You’re using the line.
Flashing green Line on hold.
Flashing red Line on hold by other stations.
Flashing yellow Incoming call transfer
Dec 18, 2009 | Video Game Consoles & Games
Intercom light stuck on and no dial tone on GE 4 line phone
You may need to assign an intercom ID for that unit by pushing one of the intercom buttons at the top.
Dec 05, 2008 | GE 2-9450C Corded Phone
GE 2-9451
You need to have the phone join the network that you are in by assigning a station address to the phone. If this the only phone that you have like this, simply remove the plastic cover where the station addresses are to be printed. Beneath this cover there is a small button labled "PROGRAM BUTTON". Use a pen, press this button, then press "INTERCOM" and then label your station (01-16) followed by pressing the # key. This will make the intercom button flash on and off red and then it will stop flashing.
I hope this helps!
Aug 27, 2008 | GE RCA 4-Line Speakerphone
RED INDICATOR LIGHTS FLASING ON INTERCOM
Thats a common "problem", but its easy to fix. The Intercom lights flashing like that is normal and they will continue to do so until you "assign" the phone its intercom number.  If you have more than one of these phones, go to your other phones, lift the handset and see what intercom number lights on that phone when you do so(the lights/buttons that are flashing). Notate which intercom number that is and move to the next phone. Once you have notated the other intercom numbers go back to the phone you wish to program and push PROGRAM , then push the touch tone key of which intercom number you wish to assign the phone (ie. 1 2 3, etc.), then push MEMORY.  That should do it, and if you need replacements their on Amazon. Good Luck
May 22, 2008 | Dual Handset Cordless Telephone with...
2-9450c telephone will not setup
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Sep 26, 2007 | GE 2-9450C Corded Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Remove power cord with no backup battery
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set.) Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
May 17, 2007 | GE 2-9450C Corded Phone
Lands Phones Logo
401 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
