Question about Troy-Bilt Pony Garden Tiller
How do i SET THE VAULVES on my pony - Troy-Bilt Pony Garden Tiller
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
Giddy up and go pony's saddle won't bounce
I am having the same problem...did you fix it
Nov 30, 2012 | Pony Little Tikes Giddyup N' Go Pony
I have an old troy bilt pony rotertiller no serial tag
The decals r a good indication, they probably didn't have any more made than they needed. The only thing i can think of is, sometimes on the back side of the flywheel, (if u ever have it off) r some stamped numbers. One set of numbers is the month, and one set is the year it was made. Now that's the flywheel, but the engine should be the same year.
ballping
Jul 26, 2010 | Troy-Bilt Pony Garden Tiller
Just bought a pony with a five horse the carb seems to be giving way to much fuel fowling the plug and spraying out the muffler
Sounds like the float level in the Carb is stuck open or set to high.
RECOMENDATION:
Shut off fuel and remove float bowl and inspect for proper operation.
INFO:
You most likely have trash keeping the float valve open or out adjustment..
Hope this tip helps.
R/
David
Jan 31, 2010 | Troy-Bilt Pony Garden Tiller
The ponies mouth
Hi, the pony's jaw is dislocated. There is a **** in the upper part of the mouth that you can look into to see where the jaw fits back in and can be popped back in place. There are also wire connections that may have come undone that can be reconnected easily.
Oct 15, 2008 | Hasbro Fur Real Friends Smores Pony
Troy-Bilt Pony Garden Tiller Logo
14 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
