Question about Sharp Cooktops
I have an old sharp microwave model r-8165, i need the cooking manual cant find it anywhere its about 20 years old, can i use any cookbook for microwave,convection cooking for this?
I just got this microwave oven from my dad, with the manual included. Do you want me to copy it and send it to you?
Posted on Jan 19, 2011
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 | Cooktops
My microwave keeps running
Thank you for your post, Lou!
From my understanding your Frigidaire microwave continues to run and when you press the second key your turntable will turn. This sounds like a potential issue with your keypad or control panel. I would recommend performing a reset on your microwave and you can do that by disconnecting power from it for at least ten minutes. This will help clear out any miscommunications within your microwave. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Jun 05, 2015 | Frigidaire Gallery FGMV154CLF 1.5 cu. ft....
How do I change the internal lightbulb?
Your owner's manual should show how. No manual, try manualslib.com
My old sears microwave light bulb is in the upper front left hand with bulb top up and socket down but behind a screen. There are screws to remove the upper fan apparatus, which appears to make the side available to extract the bulb. Probably a very special bulb, so I would get one before going to that trouble. It might also be the switch that is bad rather than the bulb. That probably requires removing the outer surrounding cover.
Apr 11, 2015 | LG LMVH1750ST Over-the-Range Convection...
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
Old kenmore gas cooktop with griddle
If the knobs will not push down and turn, this indicates the gas valve stem has become contaminated with cooking debris. The only solution to this, would be to replace the gas valves. With the cooktop more than 10ys old, parts may be difficult to find. If you can find parts, they will probably be prohibitively expensive.
Jun 28, 2008 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
Coils don't heat
The control knb are being worn need to replace it the terminals are rusty conductance may not flow./not heating the coil.
Dec 24, 2007 | Jenn-Air Expressions AC110 Electric...
Cooktops Logo
118 people viewed this question
Top Sharp Cooktops Experts
Paul Carew
Are you a Sharp Cooktop Expert? Answer questions, earn points and help others
