Question about Canon PIXMA iP1600 Printer
Refilling ink cartridge
I need to refill a lexmark # 29 color cartidge and cannot find any instructions on how to do this.. Can you point me in the right direction?
    Novelist:
  • 85 Answers
Hi you can get them here it is the same as yours
http://www.disc-info.com/downloads/jr-refill/lexmark/jr-lex-18c0781.pdf
Cheers for now
Tinteiros (Ebay)
Posted on May 31, 2008
When writing a Lexmark X5690, this text is displayed in the display (color cartidge replacement required. A variable amount of ink is in the catidge), what should I do now. Can it be refill ink?
There are some refill kits,a little messy. You could try resetting ink cartridges to see if it allows it to function properly ultimately it will need to be refilled or changed .
Jan 05, 2018 | Lexmark Office Equipment & Supplies
Instructions for refilling cartridges on a Lexmark Prevail Pro705 printer
Please note that Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark.
Feb 19, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Problems with Lexmark X2550. I have refiled for the first time a lexmark 28 cartidge. Now I have paper jam all the time, I cannot print and I don`t know what to do. I blame the cartidge, because before...
    “Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
    Oct 03, 2009 | Lexmark X2550 All-In-One Printer
    Refilled ink cartridges at Walgreens, printer won't recognize
    Hello!
    28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
    You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
    If you find my answer helpful, please vote. Thank you!
    Aug 05, 2009 | Lexmark X2550 All-In-One Printer
    Still getting message empty cartidge lexmark x2650
    May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
    My Lexmark z22 printer will not print corretly
    May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
    Ink Cartrdige Won't Print
    it is because the cartridges are non refillable..... they have a memory chip in them and can not be refilled except by lexmark thru their recycle center
    Mar 22, 2009 | Lexmark X5650 All-in-One InkJet Printer
    Canon PIXMA iP1600 Printer Logo
    96 people viewed this question
    old marine
    old marine
