Question about Yamaha Full-Size Keyboard
Yamaha Piano Keyborad YPP 50 has lost its sound. Any ideas to fix. Thank you
3 Suggested Answers
hamhm
SOURCE: keys not sounding as loud as others
Hi, BHOWDY.
Probably the best thing to do is call the Yamaha service center nearest you. I live in the Los Angeles area, and the Yamaha service center closest to me is in Buena Park. I called them on the phone and told them what the problem was, and they knew immediately what parts were needed and they shipped them out that same day.
The contacts that seem to wear out the fastest are the ones near the middle of the keyboard. On my CLP-170, it's the keys between middle C and the G above that -- probably no more then 4 or 5 keys. However, I ordered replacement contacts for all 88 keys because once you take the piano apart to replace the contacts, you may as well replace all of them.
Good luck, Howard
Posted on Sep 29, 2008
  • 63 Answers
SOURCE: Yamaha P-200 electric piano does not have any
Plug in your ear phones to see if you can hear the sound that way. If not you are experiencing some internal failure in your integrated amp output.
In that case you will need to get authorised service.
Posted on Oct 06, 2009
On my new (2nd hand) Yamaha YPP-50 piano, the middle D key is slightly lowered and requires a lot of strength to get sound from it. I'm wondering if its possible to fix? Maybe without going to a Yamaha...
There is a narrow padding strip that runs under all the keys going across. It is made of a type of felt. It is worn or torn in that spot. If you are careful and have some mechanical skill at opening the unit, you will see it, it should be a pretty simple fix to glue the felt back (if torn) or even to glue a small piece of felt in that spot to raise the key, which will allow full movement again so it would feel pretty close to normal again.
Mar 29, 2013 | Music
Key doesn't work properlyon yamaha p95 piano
take it back, its still under warranty. That means the key has a contact problem in the circuit. you have to take it all apart, clean it, check the contacts....probably lint. You can try vaccumming it and it might fix the problem. I bought one too and it wasnt good
May 07, 2012 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
Yamaha ypp 100 keyboard.No sound from G5 to C6 (inclusive). Everything else ok
You have lost one of the matrix strobe lines that scan the keyboard. Download the schematic for the YDP131 here... it will be close to your unit:
http://elektrotanya.com/yamaha_ydp-131_131c_sm.pdf/download.html
Scroll down to the "Get Manual" and click on it to download. On papge 85 of the PDF file you will see that note G5 to C6 has the common strobe line on connector C1 pin 4 as signal B13 which is the strobe for the notes in question. This is the single point of failure for those notes. Could be bad connection, broken circuit trace (happens) or something wrong with the driver. Parts are availablle for the board from Yamaha America in CA if the board is cracked. Do check for cable connector problem.
Apr 27, 2011 | Yamaha Music
I have a Yamaha ypp 100 keyboard that was sitting idle for awhile. When I turned it on and started to play there was no sound/an extremely faint sound from the speakers.
Try headphones... possibly the switch contacts on the headphone jack which disconnect the speaker when headpones are plugged in. If you can hear via the headphones, check the switch contacts. Also look for a loose cable.
Contacts can oxidize when idle for a long time.
Jan 17, 2011 | Yamaha Full-Size Keyboard
Oct 06, 2009 | Yamaha Full-Size Keyboard
Yamaha P-120 Piano: Graded Hammer (NOT key) dysfunction?
My opinion is you should take the instrument to a yamaha authorized service center.. It's doubtful this will be user serviceable, particularly if the problem isn't on all the keys, and the service center will have access to the parts needed as well as more information from Yamaha than they will share with an end user.
Mar 15, 2017 | Yamaha Music
Keys not sounding as loud as others
Hi, BHOWDY.
Good luck, Howard
Sep 29, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
302 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
