Question about Dell E152FP 15" Flat Panel LCD Monitor
My computer monitor is a black screen....the light is lit solid green and I can hear the software playing just no picture
  • 2,229 Answers
If the light is green, I suspect that the backlight has gone out on you. This could also be caused by you having the brightness turned all the way down.
Posted on Oct 04, 2010
Laptop dvd/rw has audio but no video
Step 1:
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced.
Feb 15, 2013 | Computers & Internet
The monitor will shot of will show no pictur ,if u restart the pc it will come back for a sec or 2 but than no pic a gian i try it on my other pc and he did it agian,i chack the conecsion i chek the...
coolvegasmik, Sorry, to hear that your "cold cathode-fluorescent-lamp-back-lit-lcd-monitor" is not working. Did you hold and point a bright flashlight 1 inch from the lcd panel when it went to "black-screen"??? Did you see any icons on the "black-screen"?? Software NOT a fix for this "black screen of death" problem. You or electronics technician will need to open L91A and look for bad capacitors or bad soldering on the power supply printed circuit board. If unit is 4 to 6yrs old, just trade-in for new wide screen unit. See video clips of swollen bad capacitors at YOUTUBE when you search "lcd monitor repair". All lcd monitors (99%) use same basic design and principle of operation. Sometimes ccfl back-lit lcd monitors can be repaired for less than $6 in parts and monitor will work for 1 to 3 more years. 12fixlouie
Jul 21, 2010 | Hyundai L91A 19" LCD Monitor
My SyncMaster 910mp LCD TV monitor switch thus not turn on. The green light bleeps and the screen goes blank. Can you help?
ritchaddison, Problem could be inside monitor. If "cold-cathode-fluoresscent-lamps" fail to stay lit. problem might be the "electronic ballast" circuit needs work done on it. Also check the "switch-mode-power-supply" for typical failure modes that result in "black screen" complaints. Remember this!! Your monitor no different than any other brand of CCFL back-lit LCD display in it's basic design and operation. Software not problem. Only you or qualified electronics technician will repair this unit. Read my and other LCD monitor tech's fixya profiles to make decision on what option you will use on 910mp unit. 12fixlouie
Mar 18, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Movie plays but screen is black
insert external AGP card in the cpu because internal display card does not suppot to picture or movie the other problems will also automatically solved
Feb 28, 2010 | Pioneer AVH-P4000DVD Monitor
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Samsung 460Px monitor turns on but no vidio signal going through. Screen turns from black to a dark blue meaning the unit is powered and I get a solid green light.
I have the same problem, the monitor has power, but i can't even switch sources, the front panel is locked and i can't tell if it responds to the remote because there is no menu or picture of any kind
Apr 24, 2009 | Samsung 460PXn Monitor
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Oct 28, 2008 | Computers & Internet
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Monitor
hi,
Unplug the monitor from the back of your computer tower. If the LCD is not displaying any Video the monitor has gone bad. If it displays self test feature check window. It could be a graphic card driver problem.
Mar 22, 2008 | Dell E176FP 17" LCD Monitor
Dell E152FP 15" Flat Panel LCD Monitor Logo
71 people viewed this question
Alun Cox
