Question about Bosch Nexxt WTMC 3300 Electric Dryer
My Bosch WTMC3300 dryer will do a couple of loads fine but after warming up, the third time we go to use it, we push the start button and the motor hums and the barrell wont turn. I will then open the door and push the switch in with a pencil and move the barrell counter clockwise and the barrell starts to spin. Is this the sign of a motor going bad?
    Sergeant:
    Champion:
  • 351 Answers
Yes it is
Posted on Oct 04, 2010
Testimonial: "Thanks very much"
  • 176 Answers
The motor is noisy befor starting ? its sign of a motor going bad
Posted on Oct 05, 2010
My Bosch Dryer Model nexxt WTMC3300 will not run. The Start switch indicating light turns on and blinks as it should. The lint light flashes a few times then goes out. But when I push the start switch,...
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
May 01, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
My bosch nexxt wtmc3300 dryer won't start.... cleaned the lint filter, took the back off and vacuumed it out, everything is lightimg up but when i hit the start button, nothing.... please help, getting...
Hello, Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting with Bosch, but with the most common there are two thermostat's/switches
which could be reset, plus a no reset hi-limit ( on the lint housing )... i.e. macmarkus_15.jpg ...which cannot be reset, but the hi-limit is the one related to heating...located on the heater housing and the other (emergency shut off/belt switch) is by the motor shown below.
Anyway,
To save time and back and forth dialog, I`ll mention the most likely and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor I alluded to which will prevent it to start in the event it was tripped for whatever reason.
This is the most likely scenario in my opinion based on your post...but again it depends on your model.
This will require you to remove the back panel again though. Once you've remove the rear panel, It will look like this image below and all you need to do is push it to the right ( from the back )...
i.e.
Since you`ve already taken the back of the dryer off before to gain access you should have no problem.
Either Scenario I alluded to will require the removal of that panel so let me know if you require further assistance to do this.
The other would be resetting the hi-limit cut out, You can see through the back vent opening when the vent tube is removed ( cannot be removed without removing rear panel the first time, but if attached a certain way can be done each time after ) and then by pushing the red button in...shown below.
i.e.
Keep me posted how you make out or if anything is not clear or if your model is completely different...some have line fuses at the back.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dryer wtmc3300 was overheating and now wont start up. Only makes a clicking noise. The time indicator lights up and thats it.
Dec 01, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
I did a load of laundry and everything was fine. Later I put another load in the dryer and pushed the button and nothing happened. When you open the door the light comes on and then when I close the door...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 04, 2010 | Whirlpool LEQ9858P Electric Dryer
My dryer doesnt heat or turn when start button is pushed
heatman101
Oct 20, 2010 | Bosch WTMC632SUS Platinum Series Nexxt...
Will not spin belt is fine a relay will click but motor will not start
There are a couple of scenarios which may prevent the dryer from starting with Bosch.
There is an auto shut off or emergency kill switch next to the motor which will prevent it to start in the event it was tripped for whatever reason.
i.e.
If you`ve already taken the back of the dryer off to gain access you should have no problem. If you never have, it`ll take some time.
Either Scenario I alluded to ( the other would be resetting the hi-limit cut out, you can see through the back vent opening when the vent is removed and then by pushing the red button in...shown below ) will require the removal of that panel so let me know if you require further assistance to do this.
i.e.
Keep me posted how you make out or if anything is not clear.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a LG DLE0332W Electric Dryer. I push the
Yes, the motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are LG certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide. The motor itself should be under $100.
Best, G
Aug 03, 2010 | LG DLE2532W Electric Dryer
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
259 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
