Question about Poulan Pro Chain Saw 46cc 20"
I have a Pulan Model 2150 chain saw. The fuel lines have all rotted off inside the tank. I have no idea which line the filter is to go on. The small line had inside the tank a coupling, I did not find anything in the tank that coupling went to. I have new lines installed into the tank but do not know how long they should be inside the tank.
  • 1,040 Answers
Thanks for accepting my Bid!
Here is a link to my Tip:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Good Luck!
Jim
Posted on Oct 04, 2010
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
Poulan PP4218 avx; tube (line) inside gas tank connecting filter has rotted and need to replace. Is there a tool used to push line onto "nipple" inside tank.
cheapest way is a new fuel tank from e-bay that has it all installed
you can remove the rubber grommet around the lines to get it out then get a new filter to push on the line BUT will it be cost effective against what can be obtained from e-bay
Aug 01, 2013 | Poulan Pro Chain Saw 46cc 20"
Craftsman chain saw 358.350870 starts but will not continue to run
look for gas tank vent. if clogged it will cause a vacuum in the gas tank and not let gas flow to Carb.
Dec 17, 2012 | Garden
How do ireplace gas filter in poulan 2055 chain saw?
the fuel line rots apart you need to replace the line pull the old hose out take a new hose cut down about a half inch cutting the line to about 1/3 slide a stiff wire down the hole and out the gas cap slide the hose over the wire and slide it back til the cut back end pops out put the filter on the end and pull it into place cut to size and install on the carb
Sep 01, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel line in tank dry rotted how do you replace
Hi classic11369...
Remove the old fuel line and filter from the tank...
You will insert a wire a little smaller than the diameter of the inside of the fuel line, and you will bend a small hook on the end of the line to fit over the fuel line (be sure to use a small wire) .
Lubricate the first 1 inch of fuel line with vasoline lightly...using your fingers or neednose pliers collapse the fuel line and insert it into the fuel tank, entend the fuel line long enought to go out of the fuel tank so you can reconnect the fuel filter...then pull some of the fuel line back into the fuel tank...
Please take time to rate me thumbs up
Sep 23, 2011 | Homelite ZR10926 16" Chain Saw
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
Fuel lines
The main fuel line goes to the bottom of the tank. The other, sometimes larger line goes to the primer bulb. This line goes just inside the tank, not more than 1"(inch).
May 20, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
