Question about Craftsman Convertible 25cc. Gas Line Trimmer
No gas getting from the gas tank to the carb. replaced hoses and filter already. can not even draw gas with primer button.
    President:
  • Craftsman Master
  • 1,545 Answers
You either need a new primer bulb (leaking air) or you have the fuel lines routed wrong. Here is the correct fuel line routing just in case:
Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Posted on Oct 04, 2010
I changed the primer bulb and now it's not getting
sounds like you hooked the lines up backwards, when you press the primer it is supposed to squirt gas into the tank on the return line cause what it does is draw fuel through the carb and back to the tank....filter line from tank goes to fuel pump side of carb and return line on carb goes to primer bulb then opposite line on bulb to tank...... so when you press bulb it draws fuel through filter in tank through carb and back to tank ! good luck! 2StrokeJim
Jun 17, 2011 | Homelite Garden
McCulloch 28cc Gas Blower MB3200, it doesn't appear to be getting gas from the lines INTO the carb... You can pump the primer bulb but it WILL NOT push it into or out of the carb... Any help???
The primer should pull fuel out of the carb, into the bulb and dump it back to the tank, if the fuel filter in the tank is blocked, or the fuel hose is split no fuel will enter the carb, so the primer will not fill, replace the filter and the fuel hose.
Jun 01, 2011 | Garden
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
McCulloch 3216 fuel primer and gas tubes routing?
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Nov 01, 2009 | McCulloch Garden
I have a McCulloch 3200 Chainsaw. I tried to fire it up after a good while of not using it and the primer bulb cracked and gas spilled out. I removed the primer assmbly and underneath found 2 hoses. One...
From the tank (filter on free end) to carburetor.
Carburetor to primer (primer draws fuel from tank through carburetor.
Primer to tank. (excess fuel returned to tank)
Without seeing a like saw logic says the upper carb fitting goes to the primer (draws the air out) If one is larger than the other the larger is probably the fuel feed (tank).
The oiler hose pressurizes then depressurizes the oil pump. That is what pumps the oil. HTH
Lou
Oct 13, 2009 | McCulloch Garden
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Replacing broken gaslines... were do they go?
the primer bulb draws gas through the carb 'C' and back to the tank'T' leaving a small amount of fresh gas in the carb.to replace the lines from filter to carb & bulb to tank,you may have to remove handle & split the housing halves to find where lines enter tank.look in tank W/ a flashlight.to replace lines cut new line on an angle,feed a piece of # 14 copper wire through hole from inside tank.slide new line over wire,the wire will help align fuel line with hole.use needle-nose pliers to push line into tank,& to pull it through once you can see it.cut off end of hose you beat up with pliers.push filter on hose to carb.drop it back in tank."T' line is the return.dosn't matter which line is through top or bottom hole.
Sep 21, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Mcculloch gas chain saw / 3200 changed fuel hoses due to rot
The line from carb goes to bulb inlet, the bulb outlet goes to tank. Line with filter goes to carb inlet.
Mar 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
Craftsman Convertible 25cc. Gas Line Trimmer Logo
1,091 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
