Question about Mitsubishi WS-73411 73" Rear Projection Television
Mitsubishi WS-73411 TV will not turn on - Mitsubishi WS-73411 73" Rear Projection Television
  • 6 Answers
SOURCE: Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Posted on Jan 13, 2008
Maanita
  • 1142 Answers
SOURCE: Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
Posted on May 19, 2008
  • 927 Answers
SOURCE: tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Posted on Sep 01, 2008
jan mczeal
  • 632 Answers
SOURCE: mitsubishi WS-65613 tv green power light keeps
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Posted on Sep 11, 2009
pabloloco
  • 2335 Answers
SOURCE: Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Posted on Apr 30, 2010
Tip
Mitsubishi Convergence IC Part Number List
<b>As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.</b><br /> <br /> <b>Mitsubishi Convergence IC Part # List (complete)</b><br /><br /><br />Ref # / Part # / Part Name & Description <br /><br />CHASSIS: VZ7 <br />MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705 <br />IC8C01 267P141030 HIC-<b> STK392-110 </b><br />IC8C02 267P141030 HIC-<b> STK392-110 </b><br /><br />CHASSIS: VZ8 <br />MODELS: VS-45607 / VS-50607 / VS-60607 / VS-50707 / VS-55707 / VS-60707 VS-70707 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: VZ9 <br />MODELS: VS-45609 / VS-50609 / VS-55609 / VS-60609 / VS-60719 / VS-70709 <br />IC8C00 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: VZ6-V15 <br />MODELS: VS-70803 / VS-80803 / WS-65903 / WS-73903 <br />IC8D01 267P120010 IC-H <b>STK392-040 </b><br />IC8D02 267P120010 IC-H <b>STK392-040 </b><br />MODELS: VS-50800 / VS-50803 / VS-60803 <br />IC8D01 267P120010 IC-H <b>STK392-040 </b><br />IC8D02 267P120010 IC-H <b>STK392-040 </b><br /><br />CHASSIS: V16 <br />MODELS: VS-50805 / VS-60805 / WT-46805 / WS-55805 / WS-55905 / WS-65905 / WS-73905 <br />IC8D01 267P120010 HIC - <b>STK392-040 </b><br />IC8D02 267P120010 HIC - <b>STK392-040 </b><br /><br />CHASSIS: V17 <br />MODELS: WT-46807 / WS-55807 / WS-55857 / WS-55907 /WS-65807 / WS-65857 / WS-65907 / WS-73907 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br />MODELS: WS-55908 / WS-65908 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br /><br />CHASSIS: V18 <br />MODELS: WT-46809 / WS-55809 / WS-55819 / WS-65809 / WS-65819 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br /><br />CHASSIS: V19 <br />MODELS: WS?55859 / WS?55909 / WS?65869 / WS-65909 / WS-73909 <br />IC8C01 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: V20B <br />MODELS: VS-A50 / WS-A48 / WS-A55 / WS-A65 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: VK20 <br />MODELS: WT-42311 / WT-A42 <br />IC8C01 267P141030 HIC -<b> STK392-110 </b><br />IC8C02 267P141030 HIC -<b> STK392-110 </b><br /><br />CHASSIS: V20 <br />MODELS: VS-50111 / VS-60111 / WS-48311 / WS-55311 / WS-55411 / WS-65311 / WS-65411 / WS-73411 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: V21 <br />MODELS: WS-48511 / WS-55511 / WS-55711 / WS-65511 / WS-65611 / WS-65711 / WS-65712 / WS-73711 / WS-B55 <br />IC8C01 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: K20 <br />MODEL: WT-42313 / WT-42315 / WT-42413 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V22 <br />MODELS: WS-48313 / WS-48413 / WS-55313 / WS-55413 / WS-65313 / WS-65413 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V23 <br />MODELS: WS-48513 / WS-48613 / WS-55513 / WS-55613 / WS-55813 / WS-65513 / WS-65613 / WS-65713 / <br />WS-65813 / WS-73513 / WS-73713 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V24 <br />MODELS: WS-48315 / WS-55315 / WS-65315 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V25 <br />MODELS: WS-48515 / WS-55515 / WS-55615 / WS-55815 / WS-65515 / WS-65615 /WS-65815 / WS-73615 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250</b>
on Jun 10, 2011 | Televison & Video
Tip
CHASSIS: VZ7
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
CHASSIS: VZ8
IC8C01 267P141030 HIC - STK392-110
IC8C02 267P141030 HIC - STK392-110
CHASSIS: VZ9
IC8C00 267P155010 HIC - STK393-110
CHASSIS: VZ6-V15
IC8D01 267P120010 IC-H STK392-040
IC8D02 267P120010 IC-H STK392-040
CHASSIS: V16
IC8D01 267P120010 HIC - STK392-040
IC8D02 267P120010 HIC - STK392-040
CHASSIS: V17
IC8C01 267P150010 HIC - STK392-570
IC8C02 267P150010 HIC - STK392-570
CHASSIS: V18
CHASSIS: V19
MODELS: WS–55859 / WS–55909 / WS–65869 / WS-65909 / WS-73909
IC8C01 267P155010 HIC - STK393-110
CHASSIS: V20B
CHASSIS: VK20
CHASSIS: V20
CHASSIS: V21
CHASSIS: K20
IC8C01 267P173010 HIC - STK394-250
IC8C02 267P173010 HIC - STK394-250
CHASSIS: V22
CHASSIS: V23
CHASSIS: V24
CHASSIS: V25
on Oct 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi TV model WS-73411 , a month ago it shut off while I was watching it. Since then it has been shuting off more and more as time goes by. It shuts off an average of 4-5 times at nite...
The next time it shuts down (I presume the green power light goes off) do the self check this model has, on front of set press and hold both the menu and input buttons for at least five seconds and release both.
Power light will blink a 2 digit error code like : 1 blink, 2 blink and repeat it several times.
1,2 is no error detected but there are other codes.
Let me know what you find.
SD TECH
Jun 01, 2011 | Mitsubishi WS-73411 73" Rear Projection...
Turns on then off
CK for open fuses and Bad capacitors
Jan 23, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Picture bows and shadow
Hello, asnowman here.
I had to reply to this post, as the other would not let me.
Your question:
Comment posted on Oct 26, 2009 Thank you for your help, do you know what board this is on? signal, main, or power? Your televsion is the 73411, and I think that your convergence IC's are on the center board, (called the power board, even though it doesn't have the flyback on it), if they are not they are on the signal board. You can't miss them they are attached to a very large aluminum heat sink and the IC's are very large as well. I hope that this answers your questions. If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Oct 26, 2009 | Mitsubishi WS-73411 73" Rear Projection...
How do i reset the v-chip. have no password
press 9 and qv buttons on remote at the same time.
Oct 13, 2009 | Mitsubishi WS-73411 73" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
WS-73411_Dead
If you try ctechnicians.com this will give technical answers
Dec 09, 2007 | Mitsubishi WS-73411 73" Rear Projection...
No HD 1080i
have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
May 21, 2007 | Mitsubishi WS-73411 73" Rear Projection...
Mitsubishi WS-73411 73" Rear Projection Television Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
