Question about Toshiba COPIERS E-STUDIO 520 Copier
Why is printing duplex docs so slow? - Toshiba COPIERS E-STUDIO 520 Copier
  • Toshiba Master
  • 653 Answers
That's the spec of the machine...
Posted on Oct 09, 2010
Lexmark t650
if it's regular bond copy paper then it most likely is the fuser. It may be cooling the temp on second pass.
Mar 26, 2014 | Office Equipment & Supplies
I have a Lexmark 3500-4500 printer. I have a Duplex doc. How do I turn the two sided option off?
Clickprint, click properties, preferences,options/setup
From the print layout tab under Duplexing uncheck Two Sided
Dec 02, 2013 | Computers & Internet
Duplex Error When Trying to Print PDF
I found that one of the papers i was trying to print was set for double sided printing, well i don't have the duplex part of it. So I kept getting the error. You have to cancel all the print jobs thru the buttons on the printer. Doing it in your computer did not help and turning off the printer did not help me. So after I cancelled all docs from printing and turned off double sided printing it was fixed.
Jan 30, 2012 | Konica Minolta magicolor 2300DL Laser...
We have a new hp lasterjet 4015n. It will print two sided, but it won't flip up the back side. I have my driver set to duplex print and flip up, but it won't flip up. Is there some setting on the...
I assume that you attached the two-sided printing accessory (duplexer) to your product:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=us&lc=en&dlc=en#N428
The duplexing has to be set in the printer's
Printing submenu
DUPLEX OFF/ON
This item appears only when an optional duplexer is installed. Set
the value to ON to print on both sides (duplex) or OFF to print on
one side (simplex) of a sheet of paper.
The default setting is OFF.
Print on both sides (Duplex) Click Print on both sides. If you will bind the document along
the top edge, click Flip pages up.
User manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 01, 2011 | HP LaserJet P4015N Printer
Cannot duplex print pdf files. No problem for over 2 years until now. Word docs OK have tried changing printing settings and default but problem persists. Advice would be really appreciated. Thanks
Printing PDF files without special software can be a problem, if you print a lot of files of different formats and need to deal with a few printers.
Total PDF Printer from Coolutils is a program features a lot of printing modes and adjustable parameters that will help to optimize the process of printing PDF files. To save the paper, it offers ability to print PDF files in duplex mode, i.e. print PDF pages from both sides of paper sheet.
You do not need to turn each sheet by your hands, as the program changes printer settings so that this process is automated.
Total PDF Printer is a perfect suit for personal or professional use for printing PDF files. It automatically connects to all printers enabled in the system and redirects printing tasks to the trays you specify.
Print PDF Files In Duplex Vertical
Feb 07, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Won't print from Microsoft Word
same problem...mine will only print out in duplex mode in word.
May 11, 2008 | Canon i860 InkJet Photo Printer
Is there away of getting around the paper orientation when I duplex.
This cant be right, if you print on one side, then it is the same as when it prints the first page of a duplex print.
Paper should be face down, head to front for both, make sure you are using duplex driver for your printer and duplex option is ticked. (4250DuplexTwotrayNetwork)\
make sure trays on machine are identified with correct papertype (tray 2 plain and tray 3 letterhead or vice versa)
printer I beleive has setting too enable duplex in print menu.
tray one in manual feeder on these.
When I set these up sometimes I install the print driver twice, ones set to use letterhead and the other plain, so customer can just choose which ever one at print time.
Usally it is set up that you go to driver and select tray or windows decides depending on what doc type is set on what you are printing.
So you need to check settings on printer paper handling and printer menu, you also need to check driver on pc, if on a network you may need to have admin rights to change driver config on server if your system requires it. But you need to check drive has coorect tray/paper type and options too
You also need to check doc type settings on individual document being printed
I have 1000's of customers, running HP (including 4250dtn and this has never been a issue raised.)
Ignore manual, stick letter head in tray 2/3 face down front and print single sided, then use same tray and do it duplex, it will do as the first one did then turn it over and print other side.
I think most customers don't duplex on letterhead, they use that as cover then duplex on plain, but I cant see it not working if you did, otherwise I would of come across it buy now, this machines format has been around for ages and they are great workhourse printers once noisy swing plate gear fault is fixed (common 4250 fault)
Nov 02, 2007 | HP LaserJet 4250dtn Printer
83 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
