SOURCE: Hoover washer model VHD9143ZD
Have the same problem. Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF position. Select again the programme and press the START/PAUSE button to switch the machine back on.
We recall having this problem with a previous Hoover washing machine and it was solved by cleaning the filter. The service manual recommends you clean the filter once a month. The procedure is as follows:
1) Open the flap
2) Only available on certain models: Pullout the corrugated hose, remove the stopper and drain the water into a container.
3) Before removing the filter, place absorbent towel below the filter cap to collect the small amount of water likely to be inside the pump.
4) Turn the filter anti-clockwise until it stops in the vertical position. Remove and clean.
5) After cleaning, replace the filter and lock by tightening the filter screw. Then follow all procedures described above in reverse order.
Hope that helps :)
SOURCE: HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
SOURCE: I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
SOURCE: user guide for hoover performa eco 1200
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=10
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
