Question about Codemasters Brian Lara International Cricket 2007 for Windows
Enter a disk key for the disk labelled ICC2007 ussualy the key can be
When i install brian lara cricket 2007 it ask for a disk key for icc2007
Posted on Oct 14, 2011
  • SM Risal Oct 23, 2012
    where is the solution?
Enter a disk key for the disk labelled icc 2007. usually key can be?
Posted on Apr 27, 2011
    New Friend:
W5DZ-4XM8LW-BV8TMB-SCJ9YK-JHG8J9
Posted on Dec 09, 2013
    New Friend:
VRAM9-A2EAV-
KXMAW-6SPUJ-EGTWQ
Posted on Sep 06, 2013
    New Friend:
WHERE IS BRAIN LARA CD KEY
Posted on Sep 08, 2017
I have Brian Lara International Cricket 2007 Original CD - PC DVD-Rom I have installed it.. but it is asking: Enter a disc key for the disc labelled ICC2007. Usually the key can be .. what next?
We at Fixda doesn't have keys for pirated computer games and personally, I don't have time to lose for looking ups cracks for you.
Buy your computer games from a legitimate provider or download another pirated version on your own risk and hope the best it should not have some nasty malware incorporated and should have some activation key incorporated.
Also you can join to some Gamers Forum where you can share information on games with other members
Aug 09, 2015 | Video Game Consoles & Games
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
Maxdata pro 5000 ir
There are many good reasons for booting your computer from a USB drive.
For instance, if you want to try out another operating system without disturbing the main hard drive on your computer, then installing the new OS on an external drive is a great way to run the system through its paces and decide whether you like it.
This approach will offer you the flexibility of being able to run both operating systems on your computer.
However, before you can boot the new operating system from the USB drive, you will need to change the boot order for your computer in the system BIOS.
Connect the external USB drive or pen drive to the computer before you power it on.
Press the "Delete" key as the computer performs the "Power On Self Test" (POST) to enter the BIOS area of the computer firmware.
The POST performs a diagnostic of components on the motherboard and does a cursory check of the hard drive, memory and processor.
The POST only lasts a few seconds; therefore, press the "Delete" key quickly.
Enter the administrative BIOS password if prompted to do so.
Once you enter the correct password, you will see the main BIOS screen.
Use the right-arrow key to navigate to the "BOOT" menu option at the top of the screen, and press the "Enter" key.
Press the down-arrow key until the cursor is on the "Boot Device Priority" label. Hit "Enter," and press the down-arrow key again to highlight the "1st Boot Device" option.
Press the "+" or "-" keys to scroll through the available boot options until the "USB Drive" or "USB-HDD0" label is the highlighted option.
Press the "F10" key to save changes and exit the BIOS setup program.
When the computer restarts, wait for the "press any key to boot from external drive" prompt to display, and then press any key on the keyboard to boot from the USB drive.
Award or Phoenix BIOS
Connect the USB drive to the computer.
Wait for the POST to display on the screen, and press the "Delete" key to enter the BIOS.
Enter the BIOS password if prompted to do so.
Tap the right-arrow key until the cursor is over the "BOOT" menu option.
Press the "Enter" key.
Press the down-arrow key until the highlighted cursor is on the "Removable Devices" option. Press the "+" key until the "Removable Devices" label is on the top of the boot device list.
Press the "F10" key to save the changes for the boot order in the BIOS and to exit the utility.
After the computer restarts, press any key on the keyboard to boot from the USB drive when prompted to do so.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
Jun 22, 2013 | Computers & Internet
How to boot from usb flash drive
There are many good reasons for booting your computer from a USB drive. For instance, if you want to try out another operating system without disturbing the main hard drive on your computer, then installing the new OS on an external drive is a great way to run the system through its paces and decide whether you like it.
This approach will offer you the flexibility of being able to run both operating systems on your computer. However, before you can boot the new operating system from the USB drive, you will need to change the boot order for your computer in the system BIOS.
Connect the external USB drive or pen drive to the computer before you power it on. Press the "Delete" key as the computer performs the "Power On Self Test" (POST) to enter the BIOS area of the computer firmware. The POST performs a diagnostic of components on the motherboard and does a cursory check of the hard drive, memory and processor. The POST only lasts a few seconds; therefore, press the "Delete" key quickly. Enter the administrative BIOS password if prompted to do so. Once you enter the correct password, you will see the main BIOS screen. Use the right-arrow key to navigate to the "BOOT" menu option at the top of the screen, and press the "Enter" key. Press the down-arrow key until the cursor is on the "Boot Device Priority" label. Hit "Enter," and press the down-arrow key again to highlight the "1st Boot Device" option. Press the "+" or "-" keys to scroll through the available boot options until the "USB Drive" or "USB-HDD0" label is the highlighted option. Press the "F10" key to save changes and exit the BIOS setup program. When the computer restarts, wait for the "press any key to boot from external drive" prompt to display, and then press any key on the keyboard to boot from the USB drive. Award or Phoenix BIOS Connect the USB drive to the computer. Wait for the POST to display on the screen, and press the "Delete" key to enter the BIOS. Enter the BIOS password if prompted to do so. Tap the right-arrow key until the cursor is over the "BOOT" menu option. Press the "Enter" key. Press the down-arrow key until the highlighted cursor is on the "Removable Devices" option. Press the "+" key until the "Removable Devices" label is on the top of the boot device list. Press the "F10" key to save the changes for the boot order in the BIOS and to exit the utility. After the computer restarts, press any key on the keyboard to boot from the USB drive when prompted to do so.
also
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/ boot from a usb drive
Apr 16, 2013 | HP s3700y PC Desktop
What is cd key of brian lara cricket
what is enter a disc key for the disc labelled ICC2007. usually the key can be
Apr 15, 2010 | Codemasters Brian Lara International...
Where is the number two piston located on a 2001 Oldsmobile Aurora?
They are all labeled, however if you are looking At the engine from the Beltside, the Even # Cyl's are ussualy on the left hand side of the engine. but just look by the fuel rail, you will find labels that will tell you which cyl is which
Feb 22, 2010 | 2001 Oldsmobile Aurora
My daughters computer crashed. It is running now
The product key code should have come with the software. Usually it's printed on a label in the CD/DVD jacket.
If you cannot find that label, you'll need to contact Microsoft to acquire this.
Oct 29, 2009 | Microsoft Office Professional 2007 Full...
T is constanly coming when i play brian lara cricket 07..i'm having windows vista ultimate.is there any solution to this prob.If so pls send it to me as soon as possible. Problem Event Name: APPCRASH ...
Problem signature:
Application Name: ICC2007.exe
Application Version: 1.0.0.1
Application Timestamp: 21444c52
Fault Module Name: ICC2007.exe
Fault Module Version: 1.0.0.1
Fault Module Timestamp: 21444c52
Exception Code: c0000005
Exception Offset: 001212f0
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 16393
Additional Information 1: 8a65
Additional Information 2: a977d7b616fbef91d447986a1e395fda
Additional Information 3: 902c
Additional Information 4: d3100cb634d31eedbe4c3e2cdaa33f77
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
when i play brian lara 2007 it shows this error plz help me
Mar 13, 2009 | Codemasters Brian Lara International...
Codemasters Brian Lara International Cricket 2007 for Windows Logo
1,579 people viewed this question
Top Codemasters Video Game Consoles & Games Experts
James Wishart
Nikki  Mclean
Nikki Mclean
Tony
Are you a Codemasters Video Game Console and Game Expert? Answer questions, earn points and help others
