Question about Sharp AR-BC260 Color Copier
Sharp arc 262
Its printing pages but then page is getting stuck at fuser unit,
had the problem of error massage H5-n1 which i cleared as suggested on your page but still getting this paper jam.
Any solution plz?
  • artsnotdead Jun 06, 2008
    having the same problem with a AR-BC260. doesnt seem to need the same fix. any suggestions for this model?
    Sniper:
  • 54 Answers
Open the Left side door and remove the fuser unit by unscrewing the large green wheel located under the frame on the left side door below the fuser unit. Lift the fuser unit using the handles front and rear sides. (be careful it is very hot). Set the fuser unit on a table or counter or desk. Look carefully at the left side, as it sits in the machine, near the middle. You should see a actuator for a sensor. Make sure both ends of the arm are in the holes where they shoud be. If it is out of place, put it back into place and carefully place the fuser unit back in the machine. Secure the fuser back in the left door and close the door.
Posted on May 27, 2008
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
How do i fix sharp copy machine AR5520N with error code H5?
H5 error is protection against big damage of the fuser caused by multiple paper jams in the fuser area. First clean and check paper way, check sensor operation and then reset the error. Reset with key operation # - INTERRUPT - CLEAR - INTERRUPT - 1 - 4 - START
Aug 14, 2016 | Sharp AR-5520N
My sharp ar 5518 is indicating h5
H5 is a fuser jamed 3 times in a row. Make sure jams are removed and fuser is not blocked( may be a fuser pawl stuck in the up position) After you clear jam you need to reset code try recycling power if this dosn't work you need the sim code Not quitesure on this model to get into sim's may be P-*-C-* or # * C * or # * interrupt * when you get into sim mode use sim 14 exe to clear code.
Aug 29, 2011 | Sharp AR-5316 Advanced Digital Imager...
H5 flashing on the display, anyone tell me what the error is please? It's a Sharp AR-161 copier
H5 doesn't show up on the service code manual. However, all error codes beginning with 'H' are related to the fuser, this is the heating portion of the machine. Be careful if it still prints despite the error code, you may damage the unit. It should be looked at by a service rep.
Jan 12, 2010 | Sharp AR-161 Laser Printer
Error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
Dec 02, 2009 | Sharp AR-507 Copier
Error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
May 07, 2009 | Sharp AR-M350U Copier
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Sharp AR-BC260
I would inspect the fuser unit for abraising on the roller or missing and/or broken pauls.
Jun 06, 2008 | Sharp AR-BC260 Color Copier
Sharp arc 262
Turn off machine, open drawer where fuser unit is and gently pull out the jammed paper. You may have to replace the fuser unit.
May 27, 2008 | Sharp AR-BC260 Color Copier
Error code H5 01
It means you have had 5 jams in a row in the fusing unit. Open the left side door of the copier (roll the finisher out of the way if you have one). Open the green handle on the top of the fusing unit and carefully remove all of the pages stuck in there. You can use the green wheel at the back to turn the rollers if need be. If you have no jam, then someone already removed it and you just need to reset the code. to reset the code, push P * Clear * on the numeric pad. when it says enter simulation number, enter 14 and push the Start button for black and white copies. The machine will reboot and your code should be gone.
If you keep getting jams, you may have knocked the Fuser exit sensor arm out of place.
Please don't forget to rate your answers.
Dec 22, 2007 | Sharp AR-BC260 Color Copier
Sharp AR-BC260 Color Copier Logo
258 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
