Question about Brother Office Equipment & Supplies
My DCP-167C WILL NOT PRINT I HAVE TRIED EVERYTHING. IT IS DISPLAYING 100% NORMAL ON THE DISPLAY. IT IS SAYING READY FOR USE ON THE PRINTER ICON. ALL INK WELLS ARE FULL.EVERTHING I TRY TO PRINT SAYS ERROR WHEN PRINTING. I HAVE EVEN RE-INSTALLED THE SOFTWARE DISC AT MY WITS END BEEN TRYING TO SORT IT OUT FOR 5 HRS
technotech
  • 183 Answers
SOURCE: Printer is online and says ready but won't even attempt to print
Click on Start,
Go to Control Panel,
open Printer and Faxes
look for the Printer which is HP C5280 or any icon related to same,
Right click
Choose set as default
Close Everything
Shutdown your computer and Printer
Check and make sure that the USB cable is connected propely
Restart the Printer first and then the computer,try Printing some thing.
if this doesnt resolve you issue then i would suggest you to uninstall the printer software and reinstall and update it from HP.com.
Please let me know about the resolution
Posted on Nov 01, 2008
  • 298 Answers
SOURCE: HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Posted on Mar 26, 2009
Fixe_You
  • 1800 Answers
SOURCE: printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Posted on Jun 05, 2009
SOURCE: Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
Posted on Aug 05, 2009
pineworks
  • 4041 Answers
SOURCE: 'The wast ink absorber is almost full' appears what should I do?
Hello The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 11, 2010
Manually clean print head dcp-j725dw
Explore the options on the printer display. Find maintenance and poceed from there. You will have to use menus anyway (on the computer or on the MFC display).
Nov 20, 2013 | Brother DCP-J725DW Inkjet Multifunction...
The Brother MFC-7840W printer was installed on a USB connection. The printer worked the previous week albeit not for all applications but at least for the Vista word program. Now it doesn't respond to...
Hi there!
You can check if the usb cable is connected directly & securely from printer to your computer. Once it's verified. The display of your printer should show the date/time.
Since the printer is displaying offline you can open Control Panel, go to Printers folder right click on the printer icon and select 'Use printer online' If you have pending documents right click on the printer icon and click on cancel documents.
Try checking for a duplicate copy of your printer driver or check which printer driver is selected as the default and has the status ready.
Right click on the printer driver that has a Ready status click on printing preferences and click on print a test page.
Hope this helps! Vikroks
Mar 22, 2011 | Brother MFC 7840W Printer
CLEAN UNABLE 46
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Feb 25, 2011 | Brother DCP 130C All-In-One InkJet Printer
I just had my computer serviced and cleared of virus. Now computer wont activate to communicate with printer. I've already tried everything suggested by the display. Computer has recognised the printer but...
delete the printer icon from the printer display window and reinstall.
you will need the driver CD that came with the printer if the printer model is not in the Windows printer install list.
Jan 31, 2010 | Dell 924 All-in-One InkJet Printer
The print is blurred.
no ink in cartrige...change the cartridge...or
try using print option....like....
fast draft/draft/normal/high qty/max dpi etc...this will be available in ur printer software that's installed in the pc/laptop....try to c if there is a printer icon in the rightbottom of the task bar...near the clock...click that printer icon and u can go into the print options...
Dec 21, 2009 | Brother DCP 115C All-In-One InkJet Printer
Mecha Error 0005
oooohhhh k
1) when you turn the printer on does the printer make a lot a noise and then display "ready"
-If not there may be mechanical issues with your printer
Nov 13, 2008 | Sony UP DR100 Thermal Photo Printer
Click on Start,
Right click
Close Everything
Oct 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
27 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
