Question about PfaFF Sewing Machines
Machine is frozen but I can't find any thread caught on the hook
    Genius:
  • 1,788 Answers
Have you oiled it lately? I would try that.
Posted on Oct 04, 2010
The needle on my Pfaff 2044 won't move and the wheel won't turn. What do I do?
There may be thread caught in the bobbin area which is not allowing the hand wheel to turn. Remove the bobbin case and check the hook for threads wrapped around the spindle and/or caught in the hook mechanism. A little clear sewing machine oil in a pipe cleaner is sometimes helpful in freeing threads in this area.
Feb 15, 2015 | PfaFF Sewing Machines
My machine will not sew. New not used but a few years old. once thread goes down to bobbin it locks and you can hear the clutch disengage. without thread you can run the needle at full speed then it
There may be a small bit of thread or lint caught somewhere in the bobbin case or bobbin holder. Brush lint away from the feed dog area, being careful not to brush lint into the workings of your machine. If you have the manual, look up how to clean lint from the bobbin. If you don't have the manual, try just taking the hook out, if possible. Run a clean toothpick around the housing and then use a clean small brush to brush out any lint or thread pieces. Put one drop of sewing machine oil on the hook of the bobbin housing. Then use a thread to "floss" your bobbin case. Run a thread through the slot and wiggle back and forth to loosen any caught thread bits. Good luck. ps If this doesn't work, repeat. Sometimes after you turn the hand wheel a bit, another piece of thread or lint will work loose and can be cleaned.
Dec 06, 2014 | Sewing Machines
The bobbin won't spin in hook
Bobbin won't spin in hook? .. you may have something blocking the thread 'path'...or sensors? Try threading manually, right through with some unwaxed floss... while the machine is turned off.. or better still.. as you do each thread 'tension' area... check with a flashlight to see there isn't anything lodged (old threads caught anywhere...) when was the last time you had your machine cleaned?
Mar 07, 2014 | Brother SE-270D Computerized Sewing...
Have Janome DC3050. Bobbin thread is getting caught on the hook shaped guard to the right of the bobbin. Hook race? I know threads got caught in bobbin and believe it bent or moved this. Now makes a...
I don't know your model but my Janome 6500 has a bobbin case held in by magnet on the underside and it will dislodge and move if there is a jam up. This then prevents it from forming stitches correctly. You need to lift out the bobbin case and put it back into position. With mine, when it has moved, the needle then strikes part of the case when it comes down. This often results in a burr in the plastic which then causes the thread to catch again even when the case is back in correct position.
There should be two marks, one on the case and one on the outside to align it to.
9k=
this is my bobbin case, and the cut away part on lower part of the image is the bit that goes into the machine away from you.
Feb 07, 2014 | Janome DC3050 Computerized Sewing Machine
The bobbin case on my singer feaherweight is stuck
Sounds like thread or lint has got on the centre spindle of the hook. and jammed bobbin inside case. unclip race and remove hook and bobbin assembly. remove feed dogs and all tangled thread. machine should then be freed up
Feb 05, 2014 | Sewing Machines
My problem is between the needle and the bobbin. The tread continues to get caught just below the needle- inside of the machine. The bobbin seems to be lifting up and thread gets caught beneath the needle
Hi. So is this a horizontal hook? Where is the thread getting caught beneath the needle? Maybe on the hook? Check your upper threading to make sure the thread passes through the thread take-up lever. If thread is not through the lever, it wont get pulled up , which can lead to multiple thread loops getting caught on the hook, not pulling off after the rotation.
Apr 15, 2011 | White Sewing 2037 Mechanical Sewing...
Thread gets caught in feed dog while free motion quilting.
First, remove the thread and re-thread the machine. If the thread isn't in the take-up lever properly, erratic problems ensue.
Next, try removing the needle plate and bobbin case and inspecting both for any nicks or burrs. (your instruction book will guide you how) These can be very carefully polished off with 1500 grit sandpaper. Also check the hook for burrs.
Feb 21, 2010 | Husqvarna Designer I
The machine keeps locking up. i have cleaned the bobbin and hook area. there was not much lint
if your machine has a front loading bobbin case, remove it and then remove the shuttle which the bobbin case fits into. most often there is thread or lint caught in the shuttle race preventing the shuttle from turning (it only needs a tiny piece of thread).
if you have done this check any gear meshing to ensure no lint or thread has been caught in the teeth of the gears.
if the machine sews ok and locks up after a few stitches then it sounds like needle threading or tension causing the problem. re-thread the machine and ensure there is sufficient needle thread tension to bend the needle a little when presser foot is down and thread is pulled through needle.
goodluck,
scott.
Jul 28, 2009 | Kenmore Sewing Machines
Thread caught in hook race
There should be a small screw on the side of your bobbin case adjust it little by little until you get the correct tension.
Jun 06, 2009 | Euro-Pro 9125 Computerized Sewing Machine
Sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Sewing Machines Logo
35 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
