Question about Sanyo DP19648 19 in. LCD TV
Air-ant. get lower sig. but not higher than 25, 31, 47, etc.
    Genius:
  • 1,175 Answers
If your antenna is a VHF , the rest of those channels wont come in.
You need a UHF antenna or a combo UHF / VHF
Posted on Oct 04, 2010
Setup wizard
what do i do fix this ?
Dec 06, 2013 | Westinghouse Televison & Video
Tip
What type of Air Filter should I use for my air conditioner / heater?
If you are wondering what type of air filter to use in your air conditioner/heater, you probably have already discovered there is a large variety of air filters out there to choose from.
There are several factors to consider when the choosing the best air filter to suit your needs.
1. Maintenance : level of difficulty ; interval of service
2. Efficiency : level of desired filtration and its affect on system performance
3. Annual Cost : Material and labor
Maintenance is something that can be overlooked at first. Afterall, it's just a filter, right? Filter types range from disposable to permanent. Disposables are pulled out, thrown away, and replaced with a new disposable filter. Permanent air filters must be removed, cleaned, allowed time to dry, and re-installed. Permanent air filters may or may not require electricity.
Efficiency is determined by a MERV rating of 1 thru 16 with "1" being the lowest and "16" being the highest. Low end residential air filters generally have a rating between 1 & 5. Medium grades range between 5 & 9. Higher grades are in the 9-11 range. Utimate is 11 - 13. The lower the rating, the lower the efficiency of air filtration but higher airflow due to lower resistance. The higher the rating, the higher the efficiency of air filtration but lower airflow due to higher resistance. Lower MERV ratings have minimal affects on your air conditioner/furnace performance. Higher MERV ratings can decrease the amount of air passing through the system creating system performance issues which could lead to system failure and/or decreased life. If Maximum efficiency is desired, it is recommended you consult with your HVAC contractor who can help you identify a filtration system to satisfy your needs without comprimising the performance and life expectancy of your heating and air conditioning system. Maximum efficiency air filtration will not only be capable of capturing fine particles, but it can also capture bacteria and smoke. If you determine that Maximum efficiency is not in your budget and/or not required, you should be able to install an air filter with a MERV rating of 1 - 11 without needing to consult with a contractor. MERV 8 has been laboratory tested to capture mold spores which are a big contributor to Mold in an A/C system. Additional Information on MERV Ratings - Click Here. Lower efficiency filters allow more particles to pass through which could end up getting trapped in today's higher efficiency evaporator coils. Today's coils have much smaller gaps than their predecessors making them more susceptible to collecting debris and requiring costly professional cleanings.
Annual Cost is another often-overlooked consideration when deciding what type of air filter to use. To determine annual cost, you must try to determine approximately how often you will need to replace/service your air filter and the costs of labor & materials involved. I include labor because if you have a hard-to-reach air filter or a high efficiency air filter/cleaner that requires special care, you may need a contractor to perform the service for you. Of course, if you are doing the service yourself, there is no labor involved with the exception of your own time and gas, etc. If you choose the ever-popular disposable air filter route, you should consider pleated-type air filters. Pleated Air Filters have more face area than standard air filters; therefore, they typically have a longer life expectancy - up to 3 times longer for every inch of filter thickness. In short, when determinining annual cost, you must calculate labor/material cost and multiply that cost by the number of times a year the service will need to be provided.
Proper maintenance and upkeep of your air filtration system is the single, most important service your heating & air conditioning system requires to keep it running at top performance and maintain peak life expectancy. Careful consideration is needed to determine what type of filter will meet your family's needs both on a comfort level as well as financially.
on Apr 03, 2010 | Heating & Cooling
Blower motor slows down when i accelerate
I have a thought you may try testing your battery voltage with the car turned off .It should read 12 volts or higher if not charge battery than check again if battery is lower than 12 volts after charging replace battery.If 12 volts or higher start engine check voltage on battery again it should be 13 volts to 14.5 volts not higher if voltage readings are lower than 13 volts or higher than 14.5 volts replace alternator.
May 25, 2013 | 2004 Ford Expedition
What is setting for fruit and vegetable draws
Lower humidity is more cold air going in. Higher humidity is les air. Veggies in higher humidity and fruits in lower. Meat can also be be stores in lower humidity.
Sep 07, 2012 | Maytag MFD2560HES Bottom Freezer French...
Ant light comes on when talking on cb
Check your antenna connections, Make sure they are clean and tight. Check your SWR, the built in swr meter is calibrated to turn the AWI light on if the SWR is 2.0 or higher. Check the coax wire for breaks, make sure it is not being crushed in a door,trunk lid etc.
Jun 25, 2012 | Cobra 29 LTD CB Radio
Samsung Ant 1 (Air) and Ant 2 (Cable)
no ant 1 is for dtv off air siginals ant 2 is for cable chann.
Feb 04, 2010 | Samsung DLP HL-P5663W 56" TV
I can not open powerpoint files made with windows XP and windows 93
check correctly...
u can open any files saved in lower version in higher version...but not the other way round...unless the file is saved specialy in lower version while using higher version...
so a PP prsentation saved in version 3 can be opened in 4 , 5 , 6 etc...but if saved in version 6 cannot be opened in 5,4,3 etc
but if it's saved in lower compatibility version then it can be opened..
Dec 25, 2009 | Microsoft Windows Vista Ultimate Edition
Running hot at higher speeds.(6 cyl) Does not have a full shroud around radiator. Does it require one?
The shroud around the radiator fan mainly assists cooling at lower road speeds - it increases the efficiency of the cooling fan/s.
At higher road speeds the increased airflow due to vehicle speed makes the fan and shroud less important in that circumstance.
Running hot at higher roadspeeds can be caused by either engine mechanical fault (blown headgasket etc) or defective cooling system:-
Check for combustion gas bubbles in coolant reservoir - and ensure engine has no other mechanical running problems.
Check cooling system as follows:-
1) Faulty thermostat,
2) Blocked radiator air flow due obstruction such as grasshoppers or other insects,
3) Blocked radiator core (internal) by sludge/scale etc.
4) Collapsing radiator hose on intake side of waterpump (due to softened hose),
5) Cooling system not properly filled with coolant due air locks in the system - bleed off any air (as manufacturer specifies) during re-fill with coolant and ensure flow to heater core is enabled.
Oct 26, 2009 | 1985 Ford F150
PH SIG ERR: 39:02:
phone sig error mean your Phone MonsterPack(software) is demaged. you need to flash back using RSD lite to make back to normal. give me what software version you have on your cell and what bootloader you have..eg.bootloader 0A.30/0A.52..SW:R479 and etc. i these so i can upload one for you
Jan 14, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Dig sig
it only has an ATSC tuner, and no clear-QAMuning options
Sep 23, 2007 | Protron PLTV3250 32 in. LCD Television
Sanyo DP19648 19 in. LCD TV Logo
65 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
