Question about LG Refrigerators
My frige has two handles, and the bottom handle for the frige was loose and came of, how can i get a new handle for my frige. Its a LG Model GR-642QVP Serial No REFER BAR CODE LABEL A.3850JZ0373A
I need a handle bracket for a LRTN22312TT
Posted on Jun 24, 2008
    Problem Solver:
  • 5 Answers
Sounds like you have a UK model LG refrigerator. Go to www.lge.com and from there you can select your region and get the phone numbers to call the UK LG Parts Dept. to purchase a new handle. Hope this helps.
P.S. I work for LG!
Posted on Jun 05, 2008
Fix loose door handle on a LG LRSC26911TT
if yours doesn't have the allen screw on the handle, you have to push the handle down(pushing it from the top) you might need a helper because it's really tight. I had a hard time removing those handles
Nov 22, 2017 | LG Refrigerators
How do I do fix the handle of my Matag refrigerator #M1TXEMMW803. It is loose on the bottom.
Maytag Repair - YouTube
? 2:17
https://www.youtube.com/watch?v=KcPy_PWb_Iw
Aug 27, 2013 - Uploaded by hpaiz69
Maytag Side by Side Loose Door Handle Repair. ... RefrigeratorDiagnostic & Repair - Not cooling ...
LG Refrigerator Repair (Part #AED37133117) - YouTube
? 1:01
https://www.youtube.com/watch?v=BXupc6y_wgw
Jul 9, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the handle is when it . ...Fridge Freezer Door Handle Replacement ...
How to fix a loose Refrigerator Handle - YouTube
? 0:30
https://www.youtube.com/watch?v=4IO60zkMXpw
Dec 12, 2013 - Uploaded by Charles Joyner
How to fix a loose Refrigerator Handle .... Refrigerator Repair - Door & handle, Amana , Whirlpool, Maytag ...
Jan 05, 2016 | Cars & Trucks
Lg Gn422s loose handle, I can't see a screw to remove the plastic handle at all
You will need to remove the door seal and expose the screws that hold on the inside plastic door trim
remove the door trim to get to the handle screws
Apr 15, 2014 | Refrigerators
LFX25975sw
There are Allen set screws on each end of the handles (Top/bottom for the refrigerator doors, left/right for the freezer compartment.) These screws are accessed through small holes in the side of the handle with a 2.5 mm (3/32") Allen wrench. There are on the bottom side of the freezer handle as it's installed. There are also mounting brackets under the handle that can be tightened with a 1/4" Allen wrench with the handle completely removed.
For pictures of the handle hardware, see page 9 of the manual for the LFX25975SW. This is page 10 of the pdf here: http://www.managemylife.com/mmh/owner_manuals/2228/LG-Bottom-Mount-Refrigerator-L0906255 . This link should display in your browser.
I hope this helps.
(Allen wrenches (Hex keys) are L-shaped tools with a hexagonal design where it contacts the screw head. You'll need the long side to get into the holes. Do not overtighten the screws - this can strip the threads. Then you'd need to replace the entire handle unless you can work a new screw into the spot.)
Apr 26, 2012 | LG LFX25975SW (247 cu ft) Bottom Freezer...
I have a loose handle on my lg ldf6810st dishwasher. Can I remove the inside of the door and tighten it?
I think these have set screws located at the bottom of the handle on the outside of the machine..
Best regards
Ck
Mar 06, 2011 | LG LDF6810ST Stainless Steel Built-in...
I have whirpool double door frige,its handle bar was broken,i want the same color of handle replacement it is in the black color
Locate your local appliance parts retailer, give them your model number, and if that handle is available, there you go.
Oct 12, 2010 | Refrigerators
Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
May 31, 2009 | Fisher and Paykel E522B Stainless Steel...
LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
Jul 29, 2008 | Refrigerators
Need a handle for the freezer
heres the parrt number, although i dont really know who supplies the part, i guess you can call lg direct
3651JA1033C titanium handle for freezer door approx $40 US
Apr 07, 2008 | Refrigerators
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
210 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
