Question about Samsung HL-R5677W 56" HDTV
My set turns off intermitently. This usually happens shortly after I turn it on.
    Sergeant:
  • 171 Answers
Have you replaced the lamp before this could be one of two things the lamp is all ready burning out this lamps last around 2-3years of use or it could be a bad ballast board if you all ready replaced the lamp and you have the same problem so if you have not replaced the lamp before the would be the best thing to replace here is the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=HLR5677W
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!
Posted on Oct 04, 2010
Ford f-150 won't start unless jumped.
Probably the new battery is defective or too small for your vehicle.
Dec 29, 2012 | 2002 Ford F-150 - King Ranch, 6 6" short...
Mitsubishi ws-55515 intermitent blurry picture
A bad connection somewhere--when it happens if picture is 3d look in menu for convergence and call up the grid of lines--if they are not perfect you have convergence issue which usually requires parts to be replaced.
In this set sometimes the chips will become flaky and convergence will jump in and out.
May 05, 2012 | Televison & Video
1999 HONDA ACCORD LX IS TURNNING OFF WHILE I DRIVE
when this stall happens notice if the speedometer drops to "0" while the vehicle is in motion, if some warning lights aren't lit (chk engine, ABS, brake etc.) when key is set to "On"!! If these issues happen when the vehicle "shuts off while driving" it may be caused by "ignition switch failure". Your vehicle may be part of a 2002 Honda/Acura recall. Symtoms include: intermitted power loss, intermitted engine shut off, some warning lights not lit, random hard starts. This happens more often in warmer/hot weather. Call your local dealer and provide them with your VIN# to check if your vehicle is still covered, they may fix it for free. Otherwise the part is about $48-$100!!
Jun 05, 2010 | 1999 Honda Accord
Crackling from set volume button makes no
Sounds like a loose connection with one of the audio/video cables inside the TV or a short. Contact a qualified service technician to do the fix.
Jan 25, 2010 | LG 32LX1D 32 in. LCD Television
Volume intermitently goes off but still have picture
Is this problem solved? I have it now, so I need the solution asap!!
Jun 22, 2009 | Samsung Televison & Video
2003 Chevy Malibu. While driving down the road turn signal keeps clicking randomly.
what this means that either you have a short in the wire harness going to the turnsignal/dimmer switch assembly . or the switch contacts inside the dimmer switch itself are shorting. this would be a good place to check for the intermitant problem
May 09, 2009 | 2003 Chevrolet Malibu
Intermitent no sound on digital, KDL26S4000 sony bravia TV
Try going in the settings and turning off "Steady sound". Or turn the audio setting to stereo, disable surround sound.
Steady Sound
You don't have to listen to commercials at a higher volume than the normal programming. This TV has a volume equalization feature for both program and commercials to enhance your audio entertainment.
Selvol
Bravia XBR 42"
Nov 22, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
UNIT TURNING ON BY ITSELF
check and see if the power button is not binding tightly on the body of the set.if everything is okay call a tech you are having a short in the power supply good luck.
Apr 11, 2007 | Onkyo TX-SV535 Receiver
Samsung HL-R5677W 56" HDTV Logo
120 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
