Question about Nikon N60 35mm SLR Camera
When turned on it flashes FE E and I can't take an exposure. Help!
    Brigadier General:
  • 3,006 Answers
FEE means that you have failed to turn the lens aperture ring to the minimum setting. This is essential on your model as it controls the aperture settings via the command dial on the body.
If you have already set the lens to the minimum aperture (minimum=highest number) then please report back with a comment for additional options and state whether the problem is with all lenses or just one.
If I have solved your problem then please let me know by taking a moment to rate my answer.
Posted on Oct 04, 2010
Over exposure at outdoor
if you read the owner manual, section exposure photos, you will get information how the camer work. and the faulty normally. Go too the section troubleshooting for to fix it the problem
Otherwise you must contact to the supplier company.
God bless you
Sep 17, 2012 | Olympus FE-330 Digital Camera
FE 20 turn off flash
Look for the flash button (looks like a lightning bolt) to cycle through the flash options. Flash options can be limited in AUTO Shoot mode.
The manual describes how to use the Flash on page 19 of the manual.
You can download the manual here http://www.olympusamerica.com/files/oima_cckb/FE-360_X-875_C-570_FE-20_X-15_C-25_Instruction_Manual_EN.pdf
Mar 13, 2011 | Olympus FE-20 Digital Camera
Taken pictures from the camera in Olympus FE 330 was over exposure and together with some tiny lines appeared.please kindly assist me to overcome this problem.thanks kind regards. nishantha
The shutter flex cable inside the lens is broken. This happens with FE-330 and FE-340 very often. As there are only cheap flex copies available, I wouldn't suggest you investing any money in repairing it as it will brake again, sooner or later. I have repaired a lot of these.
Jan 24, 2011 | Olympus FE-280 Digital Camera
How do u turn off the flash on the olympus fe-170? im going to a clapton concert tonite and i need the flash to be set to off i tried everything and i cant turn it off....please help!...thanks!
Press Right-arrow (marked with the lightning bolt) repeatedly to select the flash mode. In this case, you want the lightning bolt inside a circle with a slash through it, indicating "no flash".
After the concert, don't forget to set it back to Auto, or the flash will never fire again :-)
Feb 25, 2010 | Olympus FE-170 Digital Camera
Change drum light is on, new drum don't help. Won't copy.
Reset the drum count by pressing "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode"
Exposure mode is far left key on panel. You need to do this fairly quickly so that the display goes blank.
Once display goes blank then key in 24 then press print, then key in 7 then press print. You should now be getting flashing 000
Turn machine off then on and light should be gone.
Short version: C,far left,C,far left,24,print,7,print
Dec 07, 2009 | Sharp AL-1340 Laser Printer
The built in speedlight on my D 70S is not synching. Seems like the flash goes off before the shutter opens.My pictues all comes out dark no matter what I try. Can you help me?
I fixed this same problem with my D70s today, after twelve months of getting dark pictures despite the flash firing. It started syncing properly after I performed the following, though I'm not sure why as I was just mucking around.
- Set Program to P. - Push button to activate built-in flash. - Push, and keep depressed same button, which will put you in Flash Exposure Compensation mode. - My Flash Exposure Compensation was on +0.3 so I set it to 0.0 by turning the front wheel. Seemed to fix it.
Sep 23, 2009 | Nikon D70s Digital Camera
Shutter speed is slow
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Apr 22, 2009 | Olympus FE-230 Digital Camera
Blury pictures
Mar 14, 2009 | Olympus FE-370 Digital Camera
Flash exposure does not work in Av and Tv mode
There is nothing wrong here - the camera computes the exposure as the flash is not firing. The flash will fire and it will adapt the power to the received light. You must go into M ot AV, fix your parameters and shoot. The flash will adapt to your whishes - only take care to not choose a shooting time to small (1/200 or 1/60 - you have settings for it).
This is not a bug, but a feature.
Aug 09, 2008 | Canon EOS 40D Digital Camera
Nikon N60 35mm SLR Camera Logo
35 people viewed this question
Top Nikon Photography Experts
Bart Pulverman
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
