SOURCE: MURRAY AUTOMATIC DRIVE, 42
Your problem could be caused because your valves are not set properly (they vibrate loose sometimes. Remove your spark plug and try to crank theengine...If it turns freely with the pulug out, reset your valves..be sure to obtain the proper spacing (gap). Hope this helps
SOURCE: 14hp twin II Briggs and Stratton 400707 locked up and simply screeches after oil change
remove the tin upper engine cover and look at the gear on the starter yes they do break the gear the gear is only $10
