Question about Beko 324250WN 28" TV
Beko TV won't turn on. The TV was on and then it just went off. TV is just over 1 year old and seldom used. Tried to manually turn it on again and the light won't come on. Any ideas? Thanks!
  • 1 more comment
  • SHAZRMCC Nov 30, 2008
    My TV was working fine then I went to turn it on yesterday and it won't come on, there is no power light showing. I changed sockets and the fuse but no good.
  • ADRIAN ELLIOTT Dec 27, 2008
    ALSO BEKO 20411ND SAME AS SHAZRMCC.NO POWER AT ALL.TV WAS FINE YESTERDAY.ITS NOT A PLUG OR FUSE PROBLEM SEEMS TO BE INTERNAL
  • vargysv Feb 02, 2009
    My TV LED is ok, it is on, when I try to switch TV on it flashes very quickly and I hear the same sound as when TV is starting, but nothing happens, that is it... It was working normally few days ago, but suddenly it stopped. I was trying to change socket and different plug as well, but nothing changed.
There is a fuse inside you could try changing. But watch out cos it seems there are parts like capacitors, the screen and flyback which can hold thousands of volts for years even unpluged, if you touch them they might render you unalive.
Posted on Jan 17, 2009
Try an other socket first then check the fuse on the plug.
Posted on Jul 25, 2008
My electricity went out when I had my window unit on and now my TV won"t come on. My tv is a lil over a year old. Why is this happening
Hi Morris
Am suspecting your electric or power supply.
I need you to try the following steps.
1. unplug all your units or appliances
2. Reset your circuit breaker
3. try to plug your tv only and turn it On, if its turn On, then your tv is Ok
4. You mention window unit, is this aircondition window type?
Now try to plug this window unit and turn it On, if electricity went out again, then the problem is in your circuit breaker.
It could be the specs or rating of your circuit breaker does not much with the rating of your window unit.
Sep 12, 2014 | universalmounts New Universal Premium Wall...
Ws65711,8 years old, working great with out problem until this one..turned off the tv normally after use, then when tried to turn on again... it turns on (green light turns on. no pictureno...
SD TECH,
Just started experiencing convergence problem with my Mits ws-65711. I have decided to try to repair on my own and have the service manual. I see also you have step by step instructions for the repair and perhaps photos of the fuses. I could really use this info if you are able to provide.Thanks in advance. I did the self check by holding in MENU and INPUT buttons and got 1 green blink followed by 2 shorter/quicker green blinks?
Aug 30, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Beko 32" TV won't turn on.
i have universal remote, how can i turn on dvd on beko
Feb 09, 2009 | Beko 324250WN 28" TV
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
TV WILL NOT TURN ON
i HAVE THE SAME TV, SEEMS LIKE THE LAMP IS OUT. BUT ONLY TWO YEARS USE? WOW. iVE HAD MINE FOR 3 YEARS WITH ATLEAST 6 HOURS PER DAY USE. WELL GOOD LUCK AND DONT LET A TECHNICIAN CHARGE YOU 200 FOR LABOR TO TAKE OUT A FEW SCREWS
Dec 17, 2007 | LG 52SX4D 52" HDTV
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Apr 16, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Beko 324250WN 28" TV Logo
673 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
