Question about Magic Chef Dryers
Dryer vanes came loose... can't figure out how to remove front or top panel to access the outside of the drum in order to tighten the bolts/screws that hold the vane in place.
    Genius:
  • 1,073 Answers
Use a putty knife and about 4 inches inside on each side insert the putty knife between the frount panel and the top and lift up on both sides, the tub will be visable to the screw holes in the tub to reinstall the vanes
Posted on May 27, 2008
Inside the drum one of the tumblers is loose how do you tighten it up?
You can tighten those baffles by getting to outside of drum to thighten the screws that hold them to drum. to get access to outside of drum;
Remove screws from door hinge
remove screws from other side of inside door as they are exaclty opposite the ones for hinges
pull off from panel by putting putty knife/screwdriver in seam between front panel/cabinet just below the sloped part of the top and pop off front panel
in the upper corners of the top/front panel is a clip that looks likea inverted "7" or if ya will a up side down "L" remove screws from the clips and remove the clip
now ya can raise top to get to outside of drum
rotate drum by hand in CLOCKWISE direction to turn drum so ya can get to each baffle
Thanks for using FixYa.com,
Gene
Aug 22, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Inside the dryer there are 3 bars that stick out to help tumble the clothes. One of them has come loose and I'm not sure how to tighten it. It appears to be attached with screws that come thru the drum...
With the front off look up in the top left and right corners for some screws that hold the top of the dryer to the side panels. Depending on your model, there can be different styles. The old maytags used 3/8 in screws up inside the corners and the newer models had 5/16 screws right up front.
Once you get the front of the top loose you will be able to lift it like the hood on a car to gain access to the drum.
Rotate the drum by hand to put your loose fin at the top and tighten up your screws. Sometimes the screws will round out the holes on the drum too much and you may want to put a washer on the screw to secure it better.
Oct 07, 2010 | Maytag Dryers
One of the "fins" inside the dryer is coming off and just needs to be tightened but I cant figure out how to get to the drum to tighten the screw.
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum, but you have to remove the front panel first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffles securing screws can now be re-tightened. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Sep 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you open the top? the padals inside the drum are coming loose
The front panel needs to be removed first before the top cover can be lifted to the rear of the dryer to access the outside of the drum and re-tighten the screws attaching the baffles to the drum. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Aug 01, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
The agitators in the drum are loose and I need to know how to get to them to tighten?
Those are the drum baffles and the top cover needs to be lifted to the rear of the dryer to access the outside of the drum, but you have to remove the front panel first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Jun 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
Inside the drum, one of the metal things is loose. It appears that it is held on with screws, so they are probably loose. Could you tell me teh easiest way to access the outside of the drum so I can...
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and tighten the baffle screws. But before the top cove can be lifted, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the baffle screws are on top to tighten it. Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
1 of 3 fins on inside is loose & hanging by 1 screw.
Access to the bottom of the baffles for tightening the screws requires the lifting of the top cover which also requires the removal of the front panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Rotate the drum until the baffle screws are positioned on the top for tightening.
May 15, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Loose vane/fin on the Maytag LDE8406ACE
On almost all dryers the top will release by itself without requiring you to remove the front. There are two small clamp-like mechanisms under the top on the front side. They can be released easily by sticking a flat-tip screwdriver straight into them and pushing in. Once you open the top you can spin the drum by hand and tighten the screws on the fins. Take not however that some fins are only placed in by plastic snaps, and if it is loose it probably means that it is broken and will require repairs.
Dec 12, 2009 | Dryers
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
DRYER FIN IN DRUM IS COMING LOOSE
Unplug the dryer, remove the door hinge screws that go into the cabinet and the two screws on the opposite side of the door opening, then the front panel can be removedby starting at the top. Once the front is off, there are two screws, one to each side that hold the top on, remove these and raise the top. You can rotate the drum by hand and the baffles are held on by the screws on the outside of the drum. Reassemble in reverse order.
Jan 06, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
155 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
