Question about Frigidaire GLMB209D Microwave Oven
Frigidaire microwave, no power,checkrd fuse it is ok?
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
Aug 10, 2014 | Electrolux Frigidaire Gallery 30" 1.7 cu....
Frigidaire FMV158FMB power issue
Sounds like the door latch switch is broken and shorting out.
Feb 20, 2014 | Frigidaire Microwave Ovens
No power at all checked fuse yd ok
The problem is the inverter board,"if 7years old or less" or the keypad control board.
Apr 25, 2012 | Frigidaire FMT116E1W Microwave Oven
Lost Power in Frigidaire Microwave
without getting inside it , i would tend to believe its the inline fuse just beyond the wire harness.
Oct 03, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidare FMCB115Gc Has power won't start up
Could be a blown fuse in the HV transformer primary circuit,bad connections to the magnetron filament,open thermal protector or thermal fuse,
Sep 03, 2009 | Frigidaire Mid-Size Microwave
No power I checked the power outlet and I have 115V there Is there a fuse some ware??
If everything is ok, the fuse of microwave oven is located inside the unit, if you have a screwdriver, unplug the power cord and open it, you'll find the fuse
Aug 09, 2009 | Frigidaire PLMV169DC Microwave Oven
We had sevseral boiling pots going underneath the over the range microwave without the exhaust fan on while also cooking in the microwave, we saw sparks in the microwave and it went dead. now nothing...
The main power fuse inside the MW may have been blown from the steam shorting out the circuitry. If so this fuse probably can be replaced. Lowes has replacement fuses.
Jun 13, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Will not start when pushing start button
Check the door switch is properly working. If it is ok the defect may be with the key pad.
May 23, 2009 | Frigidaire Mid-Size Microwave
My microwave doesnt work at all
If the micro is completly dead and the outlet is OK... check the main fuse inside the cover. Unplug unit, remove cover (screws in back) and check the fuse where the power cord comes in through the back.
I am not sure what region you are in but in the States it is usually a 15A fuse. REPLACE ONLY WITH EXACT FUSE. Most hardware stores have these for microwaves.
MM85
Jul 22, 2008 | Frigidaire FMT116E1W Microwave Oven
Frigidaire GLMB209D Microwave Oven Logo
192 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
