Question about GE 24 in. GSD6660GSS Built-in Dishwasher
GSD 4260 J00 SS Ge Profile Dishwasher dial sticks in the heat postion, often won't turn off - Thank you
SOURCE: purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Posted on Aug 06, 2009
  • 572 Answers
SOURCE: GSD 2600 Dishwasher; water enters, but no spraying/washing going
check the chopper assembly
Posted on Feb 08, 2010
SOURCE: GE Profile Dishwasher Mod. #GSD 4430
I have the same problem right now. What is the casue?
Posted on Mar 04, 2010
SOURCE: GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Posted on Apr 08, 2010
tbirdfan1
  • 3051 Answers
SOURCE: My dishwasher GE profile quiet power II MV832134B
Hello there again
I think we got disconnected in the chat room so i will post the solutions here for you to check ok
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt If the motor isn't turning or working, the unit won't drain. at all." If the motor hums but doesn't turn, it may need to be replaced.
Posted on Jun 27, 2010
What causes the water to stay running on a ge gsd series dishwasher?
The float is stuck it may need to be replace it is located on the front left side of the dishwasher
Apr 08, 2013 | GE 24 in. GSD1000G Built-in Dishwasher
GE Dishwasher Won't turn on
Door may not be fully closing for some reason.
Mar 15, 2012 | General Electric GE Profile Dishwasher 24...
The panel on my ge profile ss dishwasher is not working...
At first thought, it sounds like the control board has gone bad. Make certain it is properly plugged in. If no luck there, call the repairman.
Feb 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ge profile dishwasher panel won't turn on
out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
Oct 19, 2008 | Dishwashers
GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
146 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
